Question about LG RU-27FB30C TV
Black and White !!!!!!!!!! aaaahhhhhh
My television is only two years old ! and I turned it on and the color is gone ! When I use the menu it has color ??? I have tried everything on the menu and tried the cable connection to see if the cable was weak . Could the tv be dying already ?? it is a 27 inch LG . I feel so retro with this tv !!!!!!!!
  • Anonymous Jan 09, 2008
    i got the same fu...k
    problem
As ther is no color & every thing normal. you have checked most of the things from outside. solution please check loose contact near chroma ic. check connector for loose. parts related to chroma section. finally chroma ic. good luck
Posted on Sep 20, 2007
My mitsubishi is in black and white even the guide
It indicates that the color wheel is not working. Either the plastic color filters are gone, or you have the color turned down in the settings. First try going to menu and check the color level setting turn it up and see if that solves your problem.
Jul 19, 2016 | Mitsubishi Televison & Video
Poor viewing quality
By poor color quality, do you mean that if you turn the color control all the way down, the black and white picture is more like black and red, green or blue - or do you have a good black and white image? If the B&W image is good, and the TV is an old (8+ years) one, maybe the mirror inside the set needs a good cleaning - especially if there are smokers in the room. If you have a B&W picture that is tinted, then you may have to go into a service menu to adjust it back to a better picture. Hard to guess the problem without more specific description of symptoms.
Jul 17, 2012 | JVC HD-56G787 Television
Gateway 42" plasma has sound only, no picture. 6 years old
Gateway 50" plasma tv #7005406 runs only in black and white after power outage. Menu screen still in color.
Mar 01, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Hitachi loses color
you are losing one of your color tubes for it to be goiing to black and white.
Jan 27, 2009 | Toshiba 57H82 57" Rear Projection...
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
LG RU-27FB30C TV Logo
313 people viewed this question
Computer Repairing
Computer Repairing
