Question about Gateway CX2618 Notebook
Need a longer lasting battery for my gateway laptop
I have a gateway cx2618 laptop I need a longer lasting battery than the original model 14.4V 6600mAh battery. Is there a compatible battery that can operate for more than 4 Hours?
I have the yellow ? for the video controller (VGA controller) Not sure where to go to install the driver. I can't find it on the Gateway site
You can download and install the video driver for your Gateway laptop.
You can download the video and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Apr 22, 2012 | Gateway CX2618 Notebook
I installed a new hard drive on my Gateway Tablet and the video controler is not installed
Install video controler
You can download the video and device drivers for yourmodel Gateway laptop from this WEB site. Make sure you select your model laptopand the correct Windows drivers. Click on this link to download the drivers: -
Hello, I recently purchased the 12-cell battery for the Gateway NV5214U which I upgraded from Vista to Windows 7. However the laptop does not recognize it. It says to remove the battery as it could...
First, you will need to check the voltages of the 2 batteries & make sure they are identical. Both batteries should have identical voltages. The only difference should be that 12-cell batteries last longer than 6-cell batteries.
Next, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
And last, if none of this works, then try updating the BIOS. Sometimes this solves problems with the battery not being detected. You can download the BIOS for your model from Gateway support site. You have to download the BIOS for your exact laptop model. I would also recommend to do some research on the Internet before updating the BIOS to see if somebody else encountered the same problem on the same laptop model, & whether it was solved by flashing the BIOS or not. Beware not to turn the power off while flashing the BIOS, or you might render your laptop unusable.
Oct 14, 2010 | Gateway Computers & Internet
My sound no longer works. whats up
make sure that all the support drivers for your sound card are all installed. To do this:
1. Right click on your My Computer icon in your desktop
2. Click on Properties
3. Click on the Hardware Tab
4. Click the Device Manager button.
5. Check that there are no yellow question marks in your SOUND DEVICES. If there are, you need to re-install your sound device software
Also, please check if your speakers are nt MUTED.
Nov 26, 2009 | Gateway CX2618 Notebook
Will not power up
I think your laptop is having some loss contact inside the Motherboard in between power supply or battery.
Usually just like this and later on it power up again normally.
My advice is you send it to gateway to see your laptop for working it properly. I do it's only a little adjustment on your laptop to them.
Sep 11, 2009 | Gateway CX2618 Notebook
I need to replace the monitor swivel on my Gateway CX2618. I need instructions. Thanks
Try these WEB sites. Use these links.
Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/searchmode...
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
This isn't for a Gateway laptop, granted. But all laptops fall into a general replacement like this.
Jun 21, 2009 | Gateway CX2618 Notebook
Gateway model # CX 2618
First test if it works on an external monitor. If it does you will need to clear the CMOS. To clear it:
remove the battery, unplug the cord, and hold the ON button down for 30-60 seconds. Then turn it on. Thats how you clear it on most laptops.
If it does not work on the external monitor, you probally have a bad video card and need to replace the old one
May 26, 2009 | Gateway CX2618 Notebook
Gateway PC Notebook/Tablet Model: CX2618 Monitor Replacement
First shine a flashlight on the screen. if you can see a very faint image on the screen the problem is the backlight. If not... it could be a few other problems, first test if it works on an external monitor. If it can then you need to cleear the CMOS. to do this you unplug the cord remove the battery and hold down the ON button for 30-60 seconds, then turn it on. If it does not work on the external monitor it is probally because you have a bad video card and need to replace it.
Jan 28, 2009 | Gateway CX2618 Notebook
I have a Gateway cx2618 laptop. The problem I am having is that when I type, any key I try to duplicate, I must wait for 2 seconds before I am able to push again to duplicate the key originally pushed,...
Hi, did you check your keyboard settings yet? At Control Panel --> Keyboard - there you can adjust the keyboard delay. That could be the problem. Give it a try and let me know.
May 15, 2008 | Gateway Computers & Internet
Gateway CX2618 Notebook Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
