Question about Microsoft Xbox 360 Console
How do I get online?
I'm trying to to connect thorugh my college system and am getting messages about the IP address and the subnet mask. I'm pretty new at this. Any suggestoins?
  • 470 Answers
Onlie?? what is your unit it is a computer????
Posted on Nov 15, 2008
TP-LINK N600
Your question is hard to follow. "got an X as it failed" what is it ?
What are the lease ip addresses from the DHCP server and what is the subnet mask ?
What is the default gateway in the DHCP lease ?
What is the router's internal IP address and subnet mask ?
What is the ip address and subnet mask of the computers used ?
What is the operating system used on computers
can you ping the router from computers ?
can you tracert www.google.com
from the dos prompt for ping (routers ip address)
what route does tracert reveal
does it get to the router
does it find the dns server ?
Nov 12, 2017 | Computers & Internet
Cisco router 1841 connected to serial interface
Make sure you set up correctly the subnet mask.
Jul 29, 2008 | Cisco (1841) Router (cisco1841)
Tip
Why Subnet Mask is used with IP address
In networking the subnet mask is used with IP address to get the Network ID. The Network ID is used to identify that the particular IP address belongs to which network. To get the network ID the Subnet Mask is AND ed with the IP address in binary format.
Example:-
IPv4 address contains 4 fields and each field is 8bit
IP Address - 192.168.10.2
Subnet Mask (Default)- 255.255.255.0
Binary
192 -> 11000000
168 -> 10101000
10 -> 00001010
2 -> 00000010
255 -> 11111111
Logical AND (formula)
* 0 AND 0 = 0
* 0 AND 1 = 0
* 1 AND 0 = 0
* 1 AND 1 = 1
192.168.10.2 ------> 11000000.10101000.00001010.00000010
255.255.255.0 ------> 11111111.11111111.11111111.11111111
11000000.10101000.00001010.00000000 (AND ing)
Hence after AND ing we get the network ID that is 192.168.10.0, so the IP address 192.168.10.2 belongs to this network.
Enjoy networking.
on Jul 08, 2010 | Computers & Internet
The WGT624 v3 internet globe is blinking but the wireless light is not illuminated
Make sure the physical connection is good between the computer in question and the D-Link gateway. If you do not have a solid link light, try swapping cables. Make sure the ethernet adapter is installed and functioning properly.
If you are running any firewall software on the computer that cannot connect, disable it. Make sure the TCP/IP settings are set to obtain an IP address automatically. Try releasing and renewing the IP address for your ethernet adapter. It should pull a 192.168.0.x address with a subnet mask of 255.255.255.0 and a default gateway of 192.168.0.1. If it does not get an IP address in this range, specify the address to be 192.168.0.10, subnet mask 255.255.255.0, and add the default gateway and primary DNS 192.168.0.1. Try and go online.
If it still cannot get online, go to the Control Panel and open Internet Options. Restore the default settings on the Security and Advanced tabs. On the Configuration tab, make sure the Dial Up setting is set to never dial a connection. Click the LAN settings button. All you want selected here is automatically detect settings, uncheck the other two boxes. Try and go online.
Nov 13, 2010 | Computers & Internet
I cannot access all websites with my wireless-n home router. what should i do orwhat could be the problem?
Nov 13, 2010 | Linksys Wireless-N WRT150N Router
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Sep 28, 2010 | Computers & Internet
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
example:
IP address: 192.168.1.13
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
note: 192.168.1.1, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
DSL connection keeps dropping off. Going to RED
well!! I have an answer for you.your comp is loosing the IP address.do this when you can go online. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 10, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
