Question about ASUS A8N-SLI Motherboard
Asus A8N-SLI Deluxe Problems Booting
I have a problem with my computer that has a A8N in it. I have hooked up all the components. The problem I have is when I try to power up, there is a split second of power, and everything works (the fans spins and lights come on), and then the whole system turns off.
  • Adarsh Patel Nov 29, 2006
    Hey, thanks for the feedback. Turns out I was a dummy and was screwing the board too tight in the case, and it was shorting itself out. Fixed it, and I recomment this mobo to anyone that is thinking about building a computer.
    Problem Solver:
  • 28 Answers
Sounds like the power supply is overloaded. Is this a new configuration? Start removing components until it powers up. If it still doesn't power up, check to ensure you don't have a short in any of the connectors that you installed components into. Sometimes when a video card, memory DIMM, or whatever, gets installed, there is a chance that a connector pin will get crushed and short out to nearby pins. If none of those work, you might want to try a larger wattage power supply. Good luck.
Posted on Nov 26, 2006
Asus a8n sli deluxe motherboard diagram manual?
Download page.
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
You must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
Oct 14, 2012 | ASUS A8N-SLI Deluxe Motherboard
No sound from my Asus MB
have you disabled the built in sound system on your computer? If you don't your softwatre can have problems picking up the right card.
Jul 06, 2012 | ASUS A8N-SLI Deluxe Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
Sli problems
Get drivers from nvidia.com; If that doesn't work reinstall windows and do the same.
Jan 05, 2009 | ASUS A8N-SLI Deluxe Motherboard
Can You Put Windows On A 1TB internal Hard drive
If your motherboard has both connections you can have both (IDE and SATA) working together
Depends of your motherboard features.
Oct 07, 2008 | ASUS A8N-SLI Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Motherboard Logo
437 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
