Re your IBM T30 no sound problem
Hi again,
Any development(s) so far with replacing the internal speakers of the T30?
I took the liberty of doing an "Ask Me" in the event that you could no longer see my subsequent posts/comments in your original post.
Cheers.
  • Louie  Role
    Louie Role Nov 21, 2008
    Since the sound is present, then the drivers and speakers are working. However,as you posted the level is rather low which could point to a couple of additional ideas:
    • the new speakers are not an exact match as to the old one, the impedance are high. Pls may I ask, were you able to check the impedance of the new speakers with an ohmmeter/continuity tester? Additionally, does the ratings/specs match the old defective ones?
    • the built-in amp of the laptop is not producing sufficient power to drive the new speakers. Pls try again the headphones and check if the level is uncomfortably loud if all the settings are at max; If yes, then amp is good, if not then amp is weak;
    • it is possible that the headphone jack needs cleaning or replacement also. It has a built-in switch that disengages the built-in speakers when a headphone is inserted. When the headphones are removed, they may not be switching back properly.
  • maopew Dec 31, 2008
    my headphone jack on my toshiba sattelite is not working .. Built in speakers are ok.. :( how ca ni make it work.?
Hi I tryed restore still no sound I ordered speakers on E-Bay It will be 4or5 days then I will install THANKS
Posted on Nov 16, 2008
  • captbrianhub Nov 21, 2008
    Hi I intalled new speakers now I have sound!! But its low volume you can hardly hear it and yes I restored to a month ago all the volume controls I can find are at 100% now what ?????Brian
  • captbrianhub Nov 25, 2008
    Iam dealing with the volume now its running very slow and some times locks up when it shuts down these programs are running and need to shut down ...ccsvchst.exe ?? hpgimzone.exe..??hpgtra08.exe its like there runing in the background PLEASE HELP THANKS also it will not let me restore????
No speaker sound
Odds are it's a damaged wire and there won't be anything you can do to fix it. My suggestion would be to get a small set of portable speakers that use the headphone jack.
Jan 02, 2014 | IBM ThinkPad T30 2366 Notebook
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Sep 15, 2011 | IBM ThinkPad Soundcard
Bought T30 used about 5 years ago, neeeded to change CMOS but has a Lock. Took out Yellow CMS battery to clear CMOS. Now can not get in computter at all. Please I am 62 years of age and enjoy my samll...
Sorry to hear of your problem. I'm not too familiar with the T30, I jumped over that series and went from the E600/X600 directly to the T4X. I'm going to guess that the T30 is similar to the X600 as it was IBM in the same era. When I've replaced the CMOS in the 600, you have to sett all of the time and date clocks all over again. You should get a couple of error codes on the screen followed by an entry into the bios.
Sep 05, 2011 | IBM ThinkPad T30 2366 Notebook
I have ibm thinkpad T30 series, installed Sound drivers but still sound is not coming in speackers and headphones
Hi
Have you checked that it is not mutted or disabled
go to control panel sound and audio and have a look in there
Nov 13, 2010 | IBM ThinkPad T30 2366 Notebook
My ibm thinkpad t30 boots up but my monitor is blank
Do you hear any startup sound when you turn it on? If there is, try hooking an external monitor. If it has good display, replace LCD, if not then it may be a videocard problem. possible motherboard replacement will resolve this issue.
May 25, 2010 | IBM ThinkPad T30 2366 Notebook
Internal fast clicking sound and VERY SLOW computer
Your hard disk might have physical bad sectors so replace it with the new one. RAM has nothing to do with this type of sound.
Jun 23, 2009 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30 wont load up
Pressing F1 is usually so accept the bios settings. This will happen if it loses all power and the BIOS internal Clock gets reset.
If you hit F1 it should get past that and let you set the clock in windows or you can hit DELETE key right as you tune it on and try and get into the bios. Some systems its F10, which ever gets you in the bios.
Then reset the bios to defaults, set the clock and reboot and see what happens.
Let me know whatever you can as far as details so i can try and help you the best i can.
good luck
Feb 15, 2009 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
459 people viewed this question
David Payne
David Payne
