Question about Sony Playstation 3 (PS3) Console
No picture i turn my playstation 3 on and it powers on but there is no picture, im using my av scart lead
    Sergeant:
  • 359 Answers
Turn hard switch off in the back of the unit. Then put your finger on the soft switch on the front of the unit. While keeping your finger on the soft button in front, switch the hard button in the back to the on position and keep finger on the soft button for 10 secs, this will reset your vid settings.
Posted on Nov 15, 2008
I need to know how to hook my DVD player to ,y Samsung TV. I have it hooked up and have a picture but its in black and white.
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Nov 29, 2011 | Hitachi Televison & Video
My playstaion 3 wont funell any picture through the av scart lead or the hdmi lead but it still turns on and is running fine ?
Please try the following steps :
Connect your PS3 up as normal, A/V or HDMI, it does not matter.
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button after you hear the second beep.
Wait for the PS3 display to be reset.
You can use this method when you change from A/V or HDMI, it simply resets the display back to standard definition
Hope this helps
Oct 28, 2010 | Sony Playstation 3 (PS3) Console
I get no picture on the tv when i turn the ps3 on. i have tried changing scart leads and scart sockets in the tv with no luck.
put your old av cables in you got with the ps3. turn system off, turn it back on using the button on the console not the control but hold the button down until you hear it beep once, keep holding it down until you hear a second beep, this will reset the ps3 back to the av outputs. you can change it to scart afterwards in the video menu settings
Jun 20, 2010 | Sony Playstation 3 (PS3) Console
How can i hook up my play station to my element tv i have tryed all the out puts and inputs on the tv
hi, are you using the scart lead fitting from the play station into the telly if you are then make sure the scart lead is pushed in all the way on the back of the telly as if its slightly out you wont get any signal.
If your using the scart lead then make sure the playstation is switched on and all the leads are in properly then you need to get your telly remote and press either the AV or source button if your remote dont have source button or av button then you need to look for a button that has a picture of a square with an arrow running through it.
Now make sure the playstation is on then start pressing the button on the remote you may need to press it two or three times till its on the right av channel.
If how ever you are using the three colored leads and plugging them into the back of your telly then you may find that this might not work but its the same as the scart lead so try pressing the same button on the remote and see what happens. if you have no luck with the three colored wires then you may need to buy a converter that converts the three colors into a scart lead you can buy these of an auction site or from any electrical or gaming shop, they cost next to nothing to buy.
Let me know how you get on or if you need further assistance ok
Nov 06, 2009 | Element ELC-HS321 32 in. LCD TV
Hi, my playstation turns on & sounds ok, the lights come on but the picture on the tv no longer comes on. i have a feeling it may be the scart lead but why would it break all of a sudden? if that is...
Hi, usually scart leads depending on their quality tend to break when been moved , unplugged or constantly adjusted, try a different scart cable and see what happens but the most likely cause is the scart.
jonno
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
Im trying to get my ps3 to connect with another tv
turn off ps3 till the red light is on the machine then you need to hold down power button to turn on until you hear a beep.
make sure a hdmi cable is not connected at back of ps3.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
Cant get picture
Turn the power on at the back of the PS3 and the red light will apear at the front, press the on button on the front and the light will then go green, then press and hold the power button on the front until the PS3 beeps at you and this should reset the PS3 from HDMI to standard Scart Cable...
Let me know if this is helpful to you :)
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi def
add a scart connection , and use this to check that the hdmi setup is correct using the system settings option
Aug 09, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
117 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
