Question about Canon PC-940 Black and White Copier
Canon PC940 Ticking noise when copying and regestration is off
When making a copy this PC940 Canon Makes a ticking noise and the top half of the original appears on the bottom half of the copy. is there any thing to check. I beleive the noise is causing the regestration issue.
Please help. Thanks a lot.
  • Carlos Perez
    Carlos Perez May 11, 2010
    sounds like you have a waste toner unit full.
    empty it.
  • Canon Expert
  • 1,326 Answers
The waste toner is in the drum unit it's self. If it full you may as well replace the drum unit all togather. Once it is full the drum is just about shoot. If the regestration is off, you may have a problem withe reg. feed clutch. Dose it show up with the paper tray and the manual feed try?
Posted on Feb 08, 2009
Tapping noise in engine
What's That Ticking Sound Coming From Your Car's Engine?
www.popularmechanics.com/.../whats-that-ticking-sound-coming-from-...
Apr 18, 2014 - My engine has developed a strange ticking sound. Its whisper-quiet before an oil change, and then makes a loud tapping after a new filter and ...
Engine Tapping - Auto Repair Help
www.auto-repair-help.com/auto_diagnostics/engine_tapping.php
ENGINE MAKES TAPPING NOISE WHEN STARTED by Mark Davidson. SYMPTOM SUMMARY The engine emits a tapping noise on start up. The noise may ...
Engine Ticking Clunking Noise - Repair - YouTube
? 9:37
https://www.youtube.com/watch?v=ilDtnJi_BS0
Mar 15, 2013 - Uploaded by knurlgnar24
One of my vehicles started making a rather disturbing sound so I went to investigate and to hopefully fix it.
Dec 02, 2015 | Cars & Trucks
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
I want a service manual for my canon pc940 copier
Just installed a new cartridge. Made one copy. worked great.
Went to make a copy today. All Black. Thought about it. Tried again and noticed lamp was not lighting. Before you say DUH! is the lamp out or is their extenuating circumstances preventing the lamp from lighting during a copy. The table top moves and everything else seems to work accordingly.
Sep 27, 2010 | Canon PC-940 Black and White Copier
Ticking noise when i start and drive
Either low oil pressure, weak oil pump, or bad or stuck camshaft lifters.
Mar 05, 2010 | 1983 Ford Fairmont
My car makes a ticking noise while it is on, what could that be?
The ticking noise is likely a sticky lifter. I've sometimes been able to resolve these by flushing the engine and adding half a cup of Marvel Mystery Oil to the oil.
Feb 26, 2010 | 1999 Isuzu Trooper
I have a 1998 GMC k1500 and it makes a ticking noise eveytime u step on the gas?
WORN PISTON RINGS MAKE A TICKING NOISE.VALVE LIFTERS MAKE TICKING NOISE.WORN DISTRIBUTOR SHAFT BUSHINGS MAKE A TICKING LIKE NOISE.
Oct 29, 2009 | 1998 Chevrolet K1500
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
My xbox 360 only plays copies some of the time
your laser is nearly dead and needs replacing, the ticking sound indicates that the laser is at the end of its lifespan OR possibly needs cleaning and the power adjusting.
we can fix this for only £40 inc return delivery to your door.
www.fixmyconsole.co.uk
uk only
Apr 01, 2009 | Microsoft Xbox 360 Console
Canon PC-940 Black and White Copier Logo
316 people viewed this question
old marine
old marine
