NO PICTURE SET WAS PLAYING FINE, NOW WHENYOU TURN IT ON IT SHOWS A WHITE VERTICAL LINE, THEN GO'S BLANK
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Posted on Nov 15, 2008
  • Sp Gupta Dec 23, 2013
    Most probably it is the TCON board which has gone bad.
I have sound but no picture. Turns on/off with no problem. Checked settings including playing DVD and other video settings- picture just went out
The model indicated has 3 picture tubes (right model?) and will blank or turn the tubes off for several reasons--almost all are protection.
In this kind of set if vertical loss of sweep (in old sets you would see just a white line left to right) it will not permit the tubes to be on as it would burn a line instantly in all three tubes screens.
If this model not likely to be a do it yourself repair.
May 28, 2012 | Toshiba TP55H95 55" Rear Projection...
Hi I have a sharp 27H S60, has worked fine for many years. Now, I get fine sound but no picture. When it is first turned on I get a thick white line in the center of the screen for a second, then it is...
The problem is a vertical deflection issue, it means the picture from top to bottom has collapsed. The set will require two or three capacitors and an ic and it is quite fixable.
Feb 07, 2011 | Sharp 27H-S60 TV
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
10 yr old emerson tv
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Audiovox AVT 1598
The vertical output IC or the vertical circuit is whats at fault. its all solid state and im sorry to tell ya that its not a user replaceable part. This set is probably not worth the repair it would take to get this set working again but please if you like ask a ;ocal repair shop what they thought about this problem.. Good Luck and please dont forget to rate this thread
Nov 11, 2006 | Audiovox AVT1498 TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
Electro Med Services...
