FixYa.com
Tags:
Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge not getting cold, fan tested and working...
posted by ecurbrenots on Nov 24, 2006
Ok, fridge no longer getting cold, removed fan from within freezer from behind panel and tested it and it runs fine. So it must be lack of power getting to it. Checked all connection when reinstalling and all looked okay.
Help, what now? What determines whether the fan receives power and how do I resolve. Unit out of guarantee and I am a student who cannot afford the £95 call out fee.
Have tried having the power off for 2 hours to ensure everything was fully powered down but when switched back on nothing.
Freezer is working fine.
Comment by ecurbrenots, posted on Nov 24, 2006
The compressor is working so does that mean it is a diferent problem, if so whats the next stage.
How do I know if I have the adaptive defrost model.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
HVACRH20
Rank:Wiz Wiz
Rating: 85%, 1208 votes
The fan won't run if the unit is in a "defrost" cycle. It turns the fan and compressor off so the heater can defrost the coils. If the evap fan isn't running and the compressor isn't running then you may be stuck in a defrost cycle. See if you have a defrost timer that can be manually advanced (looks like a screw head that can only turn clockwise direction). It could be located in the frige section on the roof area. Usually a small hole mixed in with other screw holes that you will have to look up into and see the clock dial screw head. If you find that, manually turn the screw (it will click as notches go by) until you can hear the compressor and fan turn on. If that happens you likely have a bad defrost timer. If you have an "adaptive" defrost unit it will be a small circuit board that controls the defrost cycle and you will have to replace the board.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE (GTS16BBS) Top Freezer Refrigerator GE GSH25JSTSS Stainless Steel Side by Side Refrigerator GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator GE GSL25JFPBS Side by Side Refrigerator GE GSS20IEM Side by Side Refrigerator GE GSS20IEP Side by Side Refrigerator GE (PSS26MSRSS) Side by Side Refrigerator
Can you Help with these Refrigerators problems?
Hotpoint FFA91 Bottom Freezer
I have a Hotpoint FFA91 Bottom... Answer This...
fridge working but freezer not...
Can you help me. The fridge on... Answer This...
freezer not working door left...
frigefreezer model pretige... Answer This...
hotpoint fridge freezer mistral...
fridge light on but not... Answer This...
Bottom freezer icing up and...
Hi there, I did ask this... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
