Question about Olympus AS-2300 PC Transcription Kit
Playback of DSS file in AS-2300 version 7.3
I am trying to playback a DSS file on my computer and the play button and intro scan (don't know if this is relevant) are greyed out. the fast forward, stop and rewind buttons all work fine. Any ideas what could be causing it?
Cheers,
Headley
  • 145 Answers
Usually this means there is no sound card set up on the pc.
Posted on Nov 15, 2008
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Hi there, I have a Transonic MP4 player & it will only play the intros for the songs. How can I change it to full play??? I dont have the user manual??
change the player settings from intro mode to nornmal play, and all should be fine. From the tiny manual that came with mine (pardon me if I paraphrase; it's almost 3am ;) ,during playback, press menu to access playback mode, press left or right for the mode you want( in this case normal instead of intro) and once your choice is made the screen will return to playback mode, hopefully playing your songs in their entirety.
Hope that helped, and sorry about it taking so long.
Cheers from NZ
Jun 03, 2011 | Audio Players & Recorders
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
Problems trying to play back images on my CF card
Sometimes if you take the card from the camera to the computer and the computer rotates the file from landscape to portrait it will no longer playback on the camera.
Aug 05, 2009 | Canon EOS 40D Digital Camera
I have the Olympus DS 71 which records in WAV. Is
The Olympus DS-71 has two recording format WMA & PCM WAV. The Software that comes with the recorder is Olympus DSS Player version 7 , you have to upgrade your software from Version 7 to Standard (free) after you upgrade to Standard version you can convert to DSS
go here for the update :
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Now the link show olympus AS-2300 don't worry about it, just download the DSS Player V7 Upgrade to Standard
Hope this help .
Apr 04, 2009 | Olympus DS-2 Digital Voice Recorder
Re: Play button on DSS AS-2300 Transcription player
several solutions you can try.. first of all, convert it to wave and try to play it (file. convert to wave)
if it is for all dss files, then the program may have to dll files that updated and will not work now
depending on operating system... windows xp media edition maybe the cause would be my first guess and there would be no fix for it...
2nd guess... service pack 3.... try to uninstall the program and reinstall it... and if you have service pack 3... go thru control panel and uninstall service pack 3 if you have it
Nov 15, 2008 | Olympus AS-2300 PC Transcription Kit
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Olympus AS-2300 PC Transcription Kit Logo
135 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
