Question about Sanyo Microwave Ovens
Microwave not heating food
My sanyo microwave EM-S3577S UK2 has suddenly stopped heating food. Yesterday morning I heated porridge successfully. My wife then went to heat something later in the day and it did not work. It has power, it counts down the time, rotates, everything except heat the food. I have tried turning off and on , resetting the power level, but no joy. Any suggestions welcomed
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Posted on Jan 31, 2010
Likely the door switch. The bottom tab on the door pushes a safety switch lever at the back of the slot. After a few years things loosen up and it doesn't always close. Try pushing in and up on the bottom of the door while it's counting down and see if it will work. I haven't fixed mine yet, I'll add here if I figure out how. :-)
Posted on Sep 16, 2014
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Microwave works but is not heating anything. microwave model is EM-S1567S UK2
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 21, 2011 | Sanyo Microwave Ovens
We have a microwave that has power to it but is not heating the food, can anyone help?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 18, 2010 | Sanyo EM-E1100 1100 Watts Microwave Oven
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Feb 01, 2009 | Microwave Ovens
Sanyo microwave
Could be the Magnatron, Diode, HV Cap or Transfomer, some also have a high voltage fuse that blow. Unless you really are confident playing with Very High Voltages, and have a meter capable of 5000v, I dont recommend you repair yourself as a microwave will happily electrocute you. Also if the discharge resistor has burnt out on the cap (assuming it was fitted on your model) the capacitor can store enough power to kill you even when the unit is unplugged so you must discharge the cap before playing with anything else to be safe.
Mar 14, 2008 | Sanyo EM-Z2100GS Microwave Oven
Sanyo microwave mod # EM-2100GS
unscrew the unit replace fuse near the transformer. this fuse is for heating....
Feb 02, 2008 | Sanyo EM-Z2100GS Microwave Oven
Sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Dec 15, 2007 | Sanyo EM-S5002W Microwave Oven
Microwave Ovens Logo
1,211 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
