Question about Garden
Looking to replace the spark plug on 14'' but can't find it?
Won't start
  • Allen Neal
    Allen Neal May 11, 2010
    what you wish to know
  • 181 Answers
What type of saw do you have....... need a little more infromation please
Posted on Feb 23, 2009
My Pulse Scout 49cc takes about 10 kicks to start in morning ok on electric start
Hi, Michael and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
10. Enricher valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Hard starting scooter 49ccScoot com Scooter Forums
Troubleshooting Your Scooter
http://www.scooterunderground.com/knowledge/manuals/documents/JetEuro50_Service_manual.pdf
Tao Tao 50cc Scooter Won Start SOLVED REPLACE CARBURATOR
Nov 18, 2016 | Motorcycles
Stopped while driving cranks but won,t start replaced spark plugs and wires old plugs smelled like gasoline
"Old plugs smelled". Likely no spark. Coil packs, distributor, points (if your car has points), etc. If you share your car make/model/year/engine, somebody might have one and know where to look. Without that info, I can only guess.
Nov 06, 2015 | Cars & Trucks
Truck won't start
First of all it looks like you need some new spark plug wires. you should replace all of them with your spark plugs. you might need a new battery. There could be lots of reasons why it doesn't start but replace your wires and plugs then go from there.
Mar 14, 2013 | iPhone Apps
Last time used 18 months ago, ran good, no problems. Tried to start it and it won't go...So I checked oil level..(good) removed the fuel bowl replaced old fuel with new fuel all looks well and cle
heat the spark plug for a few minutes then put back in the engine. sometimes works when you not used engine in a long time. it will take a good few goes to get the old fuel out of the carb, the heat helps burn old fuel.
Jul 09, 2017 | Motorcycles
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Just bought a poulan 14 inch chainsaw...filled it with bar oil and the gas oil mix. Trying to start and won't even turn over. Any suggestions?
If it wont turn over, it may be because the cylinder is full of fuel, remove the spark plug under the top cover, with the plug out does it no crank over, if so give it a good few pulls to clear it out, replace the pluf and try again, using no choke and full throttle, just one point you didnt fill the fuel tank with oil by mistake??
Jul 18, 2011 | Poulan 14" Chainsaw
Won't start after washing it, tries to turn over just won't start
check / remove the spark plug from cylinder head ,clean and dry them both,might water gets into it...
possible should adjust the spark plug tip allowance,make it slight closer.
or try to replace another spark plug. good luck..
hope it helps... please rate me if this is helpful...thanks
Jun 05, 2011 | Suzuki GSX-R 750 Motorcycles
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
