2003 Mitsubishi Galant Logo
Posted on Nov 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car sputters when you accelerate
When i accelerate from a start and cruising the car has a hard time accelerating. It shakes a lot and sputters. I replaced the spark plugs and air filter. What could it be???? Please i need help ASAP!
  • 3 more comments
  • coolcapj Nov 15, 2008
    The engine light has been on for quite a while, before this problem. I was getting ready to borrow a computer check and check the code but i haven't been able to. it idles very rough in drive, it shakes a lot. But in park it idles so so and then sometimes it shakes and then stops.
  • Anonymous Jul 18, 2013
    did anyone find the answer for this problem? my car is doing the same thing. i cant figure out what is wrong with it
  • christopher goodwin
    christopher goodwin Sep 27, 2013
    idle air control valve....temp fix is to take off the air hose leading to it and spray with wd40...long term fix...go on ebay buy the part for 40-50$ and take 5 mins to replace it. the dealership will try to charge 900+
  • Anonymous Mar 13, 2014
    I changed the fuel pump, fuel filter, spark plugs, air filter, changed the oil, changed the tranny fluid, changed starter & my car is sputtering when I press on the gas & when I reach over 50mph my check engine light starts blinking...this is getting so frusterating to figure out what is wrong?? Someone please help!!??
  • Anonymous Sep 02, 2014
    Not sure if you ever fixed the problem but it sounds like a TPS throttle position sensor sometimes if you locate on the throttle linkage it will have a plug going to it disconnet it and see if the car accelerates most of the time it will stall if the check engine light is on you can take it to a Autozone if you have one near by and they will run the code amd let you know what part you need I would fugure it would be the TPS or Air Flow sensor both very simple to replace yourself.
autodr
Level 2:
  • Expert 260 Answers
  • Posted on Nov 15, 2008
autodr
Expert
Level 2:
Answers
260
Questions
Helped
204490
Points
961
Is the engine lite on? if a misfire shows, and the plugs are new, could be coil or wires. how does it idle? maybe air leak between mass air flow sensor and throttlebody.
  • autodr
    autodr Nov 15, 2008
    autozone will scan for free, they are just unable to clear it, if that helps any.
Csquared Cole
Level 1:
New Friend:
  • Contributor 39 Answers
  • Posted on Jun 10, 2015
Csquared Cole
Contributor
Level 1:
New Friend:
Answers
39
Questions
Helped
16423
Points
79
Is this a 2.4? I had one that the balance shaft belt broke and made the timing belt jump. Had the same symptoms as you. Vibration comes from the unbalanced oil pump shaft, sputtering could come from the timing being off.
miloisbest
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 26, 2014
miloisbest
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4985
Points
6
May be the micro filter in the high pressure fuel pump. This pump is located in the engine bay. The vehicle also has a low pressure pump in the tank. If the high pressure pump is not delivering fuel to the fuel rail effectively in the GDI versions, the car will die under load. Its not a big job to do usually its a kit replacement with o rings and a micro filter. Probably a job for the serviceman.
1helpful
What to do with sputtering and lack of acceleration
Scan for codes stored ion the OBD computer. Many auto parts stores can do this for you at no charge. Based on the results - a complete tune up may be in order.
Car started shaking after hard acceleration
Fill up coolant,cap it is bad replace,check hose,start car and look.
Acceleration problem
possibly camshaft position sensor in the distributor, or weak fuel fump starts acting up when warm, or throttle position sensor. heat has a effect on sensors and electrical components in some weird and hard to find ways.
2helpful
I have a 2000 ford expedition. Out of the blue it started sputtering and shaking when I accelerate. Vehicle has144,000 miles.
Sounds like one of the coil over plugs have gone bad. this will cause mis-fire which causes your car to sputter, skip, and shake. It can be changed easily when finding out which one it is. But rather expensive for a simple part $40+ each.
8helpful
2answers
07 equinox sputtering on acceleration
to funny, My car an 07 equinox with 52000 miles on it just today started sputtering. I googled equinox sputtering and I came up with this sight reporting the same exact problem-- help
Car shakes when i floor it?
More than likely missing (Misfire) they are prone to engine wiring harness going brittle and causing a misfire
1helpful
Rough idle, Car shakes, sputters and misfires upon acceleration
It sounds like you may have a problem feeding the fuel to your engine, I had the same problem with my 89 RS. All the 1989 model's fuel systems were recalled. I think you may need a new fuel pump. The fuel pump is located inside the gas tank in the rear of the car right under the rear axle. The fuel pump itself isn't too expensive, but with other small parts such as the electrical harness upgrade and fuel filter and the labor you should be looking somewhere in the $500 range. I hope this helps.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
