Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp power supply
My lamp indicator light was on so we changed the lamp in out Mitsubishi wd 52525 and the lamp indicator is still is lit. I took the back of the tv off and I can see when I turn it on the lamp lights for 3-5 seconds and then off. I saw a resolve issue one of Fixya pages but am not sure what board it was referring too.
  • 179 Answers
Most likely the main power supply board is bad and has badd 3300uf caps
Posted on Nov 17, 2008
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My wd-52525 lamp indicator indicated that I needed a new lamp. I purchased a lamp, installed it and of course it still indicates a bad lamp. I took the lamp assembly and had it checked out by a tech and it...
Actually Tim, it seems more like a ballast issue, I recommend you replace it, since ity doesn't have enough energy to keep up with the lamp, and that's why you gte a lack of image.
Aug 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My power supply is not working
That problem is usually related to failed capacitors on the power PWB. You can get a kit called the V26 Power pwb repair kit at the following link which contains the replacement capacitors and a a CD with instructions at the following link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
you can check this first before you replace lamp. F9a09 and c9a37, c9a38
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Lamps have been known to burn out the power supply to the DM assembly. If there is no visible damage to the lamp, your problem may be the power supply or the board. Good luck.
Oct 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
