Question about Hitachi 53SBX59B 53" Rear Projection Television
Running out of Brightness
Picture is dark and brightness is at 100%. Also seems to be too much blue. Just started past day or two. Set was purchased in 2000.
  • Anonymous Apr 15, 2008
    i have the same problem where the picture is really dull and dark, anyone no how to manually adjust this tv without useing magic focus button
    President:
  • 4,402 Answers
Use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
SOURCE:
Monitor is set to 100%--still too dull
If the picture is dark, on screen brightness will not overcome this.
Apr 01, 2014 | IBM E74 Monitor
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Why is my picture
Since you do not supply information (type, brand, model, age)
about your set, it is difficult to guess at your problem. The settings are there (contrast, brightness, color) for you to readjust the set as it ages and are not often used past the setup stage when you get a new set.
Gamma is the base level to set the black part of the signal.
I do not know what lamp you would have in a TV set.
Dave
Jul 04, 2017 | Televison & Video
Why do i have to have the brightness set at 100% or you cant see the picture
Hello
If baklight CCFL tubes become weak, the brightness will be very weak. Now you can see the picture with least brighness. So it is sure that, the backlight inverter board is working well. Just check the CCFL lamps. For a 37 inch LCD tv may have atleast 14 CCFL lamps. When replacing, do replace all at one time. OK.
Dec 18, 2011 | LG 37LH3000 37" HDTV LCD TV
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
Dec 10, 2008 | Toshiba 36AF41 36" TV
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Screen Brightness
Your ballast may not be up to 100% of its rated capabilities, thats often the cause when the brightness level gets to unwatchable levels. You may need to troubleshoot the ballast voltages a defective ballast can usually cause a lamp to loose about 60 % of its brightness levels. The other possibility could be the DLP mirrors need polishing but that is something better left to a repair shop as the DLP mirrors are sensitive
May 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Color and brightness problem
Has it been dropped? At first it sounded like it may be have been an intermittent short if the CRT guns, but it's hard to say. Since it doesn't seem to be the cable, it sounds like this one needs component-level troubleshooting.
Jan 07, 2007 | LG Flatron F700B 17" CRT Monitor
Hitachi 53SBX59B 53" Rear Projection Television Logo
135 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
