Question about Samsung Televison & Video
Our Sansung 40in. TV screen has vertical and hozintal lines
If you hit the TV the lines  go away and a picture returns; only to have the line appear again and we  go to the process of hitting the TV inorder to have the picture return
    President:
  • 2,712 Answers
This is indicative of some poor/broken solders on the board or loose wiring. If you are experienced in electronics/tv repair, open the TV and inspect the main board for faulty soldering and redo the same. I would first check the connections on the horizontal amp, and the surrounding caps and resistors..
However, if you do not experience in this type of work, I recommend calling a repairman, as there are voltages in the TV that can kill, even when unplugged.
All the best!
Posted on Nov 15, 2008
Why does it have vertical lines and no picture?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 16, 2016 | Vizio Televison & Video
Veritcal yellow line on 50" sceptre tv
The edge ribbon connector may not be connecting (on the inside of the tv). Cure is foam strips between screen edge connecters and inside cover. Or, Memory chip (used to make the picture appear), may be bad. All flat panel tv's use a memory chip to make picture appear (it is digital after all). And if memory chips are bad, picture will have lines, jags etc. But it sounds like you have edge connecter problems. Place foam between inside cover and screen. TV may have been thrown around in shipment, and edge connecters came undone. They're very lightly soldered on some sets.
Dec 25, 2013 | Sceptre Televison & Video
Have NEC LCD 40 inch tv which now has no sound or picture with coloured lines down he screen, is it fixable or has screen given up??
Uh-Oh....Vertical lines, NO PICTURE. That is NOT good.
Did your TV get hit or fall over?
The LCD panel is actually broken.
If you had a picture on it, it would still be a bad LCD panel, but when you get lines and no picture, it means the row/column bus has been severed somewhere.
The downside is the LCD panel will cost the same or more than the TV set.
I wish i could have a better solution.
Let em know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 01, 2011 | NEC 40IN LCDTV 1920X1080 1000:1 40 in. LCD...
Horizontal line at top of screen in any hd format with componet or hdmi. model is sv470m. the tv isn't even a week old.
Get into the TV menu and locate the H (Horizontal) and V (Vertical) picture options. . .increase the V until line at the top is gone.
Oct 20, 2009 | Vizio SV470M LCD TV
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vertical lines on sansung hln5065w tv
Bring up the on screen menu if you see the lines in front of the menu replace the DMD board.
Feb 19, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
Televison & Video Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
