Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My power supply is not working
My lamp indicator light was on so we changed the lamp in out Mitsubishi wd 52525 and the lam indicator is still is lit. I took the back of the tv off and I can see when I turn it on the lam lights for 3-5 seconds and then off. I saw a resolve issue one of Fixya pages but am not sure what board it was refering too.
  • 8 more comments
  • jmontoya Nov 15, 2008
    I will try it thank you
    is the V26 for the ballast?
    so the V26 will have what I need to correct the power on the ballas?
    so if I were to open the back of my tv again where would I look? We paid a technician to come out and he said it was the ballast board but I also saw him struggling to change the lamp.
    I have the service manual I will take it off and see what I can find
    I found the board that says power. the wires that are for the ballas are connected to this one, is this one the one I am looking for?
    what do they look like?
    light pink little things?
  • jmontoya Nov 16, 2008
    ok looking at the diagram I have two that are bulging, one has something on the top of it. these are what I will need to replace with that kit?
    thank you I will let you know how it goes. my parts should be here Wednesday/.
  • jmontoya Dec 29, 2008
    Ok tv was working great and know.....we can watch about a movie and a half and the check fan light comes on. When I was doing this all to the tv I notices that there are three fans. Which one is it talking about, I cleaned all three of them when I took the back off to replace the capacitors.
  • Mitsubishi Master
  • 8,617 Answers
That problem is usually related to failed capacitors on the power PWB. You can get a kit called the V26 Power pwb repair kit at the following link which contains the replacement capacitors and a a CD with instructions at the following link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Posted on Nov 15, 2008
  • 7 more comments
  • Sonny Berry
    Sonny Berry Nov 15, 2008
    Youre welcome, thats the usual repair for the V26 DLP when the lamp isnt the issue, they are famous for the Capacitors failing.
  • Sonny Berry
    The ballast hardly ever goes out on that model, its almost always the Power bord that powers the ballast which will cause the lamp led to turn red. The ballast usually wont trigger a lamp error if its defective
  • Sonny Berry
    The kit I listed above V26 Power Pwb kit repairs the power board which powers the ballast, there isnt any kits to repair the ballast, as the ballast hardly ever fails with mitsubishi its almost alwasy the power PWB which isnt the ballast.
  • Sonny Berry
    The power board is located inside the Chassis block which is all encased inside a large metal container. Most repair shops that are not famillar with mitsubishi DLPs will assume its the ballast, but its almost always the capacitors on the power PWB. I wouldnt attempt to remove the chassis block without the instructions or the service manual, as its a proceedure thats best done when you have the disassembly info in front of you.
  • Sonny Berry
    ok youre looking for the board called the power PWB it will be indicated where the board is located within the chassis block , its on the opposite end of the chassis in relation to the terminal PWB ( input Boards)
  • Sonny Berry
    yes thats the power PWB board that will have the failed capacitors on it there are eight cpacitors that typically fail on that board
  • Sonny Berry
    Sonny Berry Nov 16, 2008
    Heres a picture of an actual V26 DLP Power Pwb with some capacitors circled on it.
  • Sonny Berry
    Yes, the kit will give you the board location numbers of the caps say for instance C9A37 & C9A38 are 3300uf 16v, and they will include the correct rated Capacitors with the correct temp ratings as you need to use the 105 degree celsius capacitors. There are eight Capacitors that need replacement on that board, The kit will identify which ones they are by board location number and rating and they will include the correct capacitors.
  • Sonny Berry
    Youre welcome. I am fairly certain the kit will solve the issue with your DLP.
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp power supply
most likely the main power supply board is bad and has badd 3300uf caps
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
you can check this first before you replace lamp. F9a09 and c9a37, c9a38
No picture
Lamps have been known to burn out the power supply to the DM assembly. If there is no visible damage to the lamp, your problem may be the power supply or the board. Good luck.
Oct 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
877 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
