Question about Casio fx-300ES Calculator
Unable to enter a formula correctly to get the right answer
1.3(4/4+1(1-0.3)+0.15(1(1-.3)/4+1(1-0.3))
I know the answer to this is 1.129 but the closest I get is 1.49965 by putting the formula in the calculator in pieces!
Many thanks.
  • Casio Master
  • 7,993 Answers
The expression that gives you the result you were looking for is as in the screen capture.
It is to say the least a very clumsy way to write it and I am not surprised you made mistakes typing it. I would too.
At leats unclutter the expression by removing all those 1 before a parenthesis. If there is nothing explicitely written before a parenthesis it is always 1x the content of the parentheses.
That is what it looks like after removing the redundant 1x
You can still do better by computing the differences inside the varunable to enter a formula correctly to get the rig - 3704b12.jpgal parentheses. (1-0.3)=0.7
You can still arrange it further. And I leave it to you.
Having a calculator is not a sufficient reason to park the brain in idle gear.
Posted on Jul 21, 2010
  • k24674 Jul 22, 2010
    Apparently I made a mistake too.
    This becomes
  • k24674 Jul 24, 2010
    One final remark. The way you wrote your expression is ambiguous. A few extra parentheses would have helped. However if you use your Casio 300ES in MthIO you will be able to check if what you key in is exactly what you write on paper (provided you use the fraction bars.)
How to enter compound interest formula
Just tell us what formula you must enter and we will show you how to enter it.
Aug 04, 2014 | Texas Instruments - Ti-36x Solar...
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
If function with array
Here is an example:-
We have to calculate result on the basis of marks.
1. Select answer range and click in formula bar
2. Type following formula
=if(d5:D9>=40,"Passed","Failed")
3. Now Press CTRL+SHIFT+Enter key
4. Observe the result in answer range and formula in formula bar, notice { } braces come automatically when we press CTRL+SHIFT+Enter key for an array.
excel3-yi4l5i2224qkwob0czw2k0fe-5-0.png For more clarification please mail on ali_zulfikar@yahoo.com with screenshots.
Apr 13, 2014 | Microsoft Excel for PC
Problem was found in Micorsoft excel 2003. When I copy the formula from one (original) cell to another (new) cell, the formula in the new cell has updated but the value show on the new cell was the...
Once you have copy the cell from where the formula cam from, on the destination cell,
go to
1. Edit
2. Paste Special
3. Formula.
4. Press Enter
This should resolve your problem. Regards.
Aug 11, 2010 | Microsoft Office Excel 2003 for PC
Is the calculator suppossed to have "DEG" in the bottom right hand corner? I am trying to enter the numbers for the compound interest formula and I keep getting "Syntax Error" Is it because of the...
The DEG indicator on the screen is a reminder to the user that the ANGLE unit is in degrees. You can change the angle unit to Radian or Grads. That does not have any incidence on other calculations. It only affects the computation of trigonometric functions : sine, cosine, tangent, arc cosine, arc sine and arctangent. So if you have syntax error in the calculation of the interest formula, I can assure you it has NOTHING to do with the angle unit.
I do not see the formula you are trying to use, so I cannot be sure what you are doing wrong.
  1. Possible wrong usage of the regular minus sign instead of the change sign (-) or (+/-)
  2. Missing right parenthesis
  3. A right parenthesis is inserted at the wrong place.
  4. Incorrect use of the power function
I suggest you write the correct formula on paper and enter it step by step. A step is defined by an operation: multiplication, division, power. Start with the content of parentheses and work toward the outside. The last result is always the one stored in Answer memory (Ans).
Dec 23, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
Need to take create a formula that takes a cell
Hi sug04
These are couple of solutions
First. Solution
  • Take away 20% means the answer is 80%
  • 20% means 0.2 of a number, 80% means 0.8 of a number
  • So If you have 200 in Cell B1
  • And you want 20% less in B2
  • Goto B1 type 200
  • Goto B2 type like this =B1*.8 and press ENTER
  • Now Cell B2 displays 160 which is the correct answer
Second Solution
  • Goto B1 type 200
  • Goto B2 type like this =B1-(B1*.2) and press ENTER
Good luck, have a nice day
Please give a Rating to this solution
luciana44
Sep 17, 2009 | Microsoft Excel for PC
Excel Formula
Make sure that the cell is formatted as a number, not as text. (Right-click the cell, format cell, number, choose NUMBER.)
Dec 19, 2007 | Microsoft Excel for PC
Casio fx-300ES Calculator Logo
67 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
