Question about Amana ALW480DA Top Load Washer
The water ran out onto the floor after the wash cycle on lw7503w2
I didn't see any water around hoses.  Is it the pump?  How do I get to it and see?
  • Anonymous Jan 02, 2009
    water on floor under machine
    Problem Solver:
  • 7 Answers
Remove the front panel. You will see two hoses connect to a water pump. The leak can be from lose hoses or leaky pump.
Posted on Jan 06, 2009
F & S GWL15 would not drain. Replaced pump & it drained for a while. Removed diverter, found a dime & some lint, cleaned it out and installed it. Still would not drain, water is on floor, do not see leak....
Have you tried reverse flushing the drain hose?
If you can get the outlet/drain hose to the washtub cold tap
wrap a towel around the hose and tap to stop water going everywhere whilst slowly turning up the water pressure
from the tap.
(Any leaks STOP and check your hose clamps/connections are all tight.)
Water should now be flowing into the machine bowl, and
hopefully turned the pump, and cleared any blockages.
Hope it helps
Sep 15, 2013 | Fisher Paykel EcoSmart GWL15
Washing Machine will not drain
the signs all point to the pump. thanks for the model number... i looked up this machine and the pump it electric 120v retails for $100. before you buy anything you need to get to the pump and take the hose off... i bet there is something inside causing your problem if not let me not then plan B
hope this was helpful
Apr 07, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
My washer isn't holding water to wash on the begining of the cycle or on Rinse. Any ideas on how to fix it?
If you mean the water runs or drains out during the cycle, the drain hose is too low. It should be as high as the top of the machine. If you mean the water leaks out onto the floor, then it could be a hose has a hole, or the pump is leaking.
Jan 28, 2010 | Whirlpool Washing Machines
The drain pump came on during the wash cycle and blew water out onto the floor. What could cause this?
you may have a broken drain hose or has become diconnected from the tub or drain pump
Sep 17, 2009 | Maytag LSE7806A Top Load Stacked...
Water spills over tank onto floor
check for object in the drain hose going to the water pump or the pump going bad also check drain hose make sure is not blocked
Jul 30, 2009 | Amana Washing Machines
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Kenmore built in dishwasher drain quit working
if it looks somewhat like a elongated and cropped figure 8 it is what we around here call a clutch drive. if it looks like a 6 point star, it is a torx drive.. Be aware, the screws holding the guard in place may also be holding the pump in place under the unit. if so removing the screws would allow the pump to fall off the bottom of the unit.
If the unit washes, the motor and pump are working (the same motor/pump that washes the dishes also drains the unit)
if the motor is not running during the drain cycle, it is most likely the timer or a connection to the timer
if the unit is not running at all, it could be the motor or timer
if the motor/pump is working, I would first ensure the drain line is not clogged (pump may be trying to drain the unit and forcing the water out were ever it can due to a blocked drain hose, this would explain the water on the floor. I have found that when a drain line is blocked, it is usually blocked where the drain hose connects to the drain pipe under the sink.
let me know what you find and we will Fix Ya.
clarkco
Feb 06, 2009 | Kenmore 15121 Built-in Dishwasher
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Amana ALW480DA Top Load Washer Logo
163 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
