Question about Cameras
Fresh batteries and no flash boot up
Hasselblad 500 cm
  • 599 Answers
Bad hot shoe or pc chord?
Posted on Nov 21, 2008
Batteries-kind
It takes five AA batteries (also called LR6 or AM-3).
If you need a manual you may download a copy from http://butkus.org/chinon/hasselblad/hasselblad_555_eld/hasselblad_555_eld.htm
Jan 03, 2014 | Hasselblad 555ELD Medium Format Camera
When take picture a flashing green light appears on display
Check that batteries are fresh. Check that camera hasn't been set for no-flash mode.
Give the flash time to charge before pressing shutter.
Aug 21, 2013 | Olympus EVOLT E-500 Digital Camera
This is not a problem necessarily, but i cant seem to find this info on the net. what type of lens is compatible with the Hasselblad 553 ELX? Can the 500 C/M lenses work?
All C and CF lenses manufactured since 1957 will work on your 553ELX. The only Hasselblad lenses which will not work are the F types manufactured after 1976 for those bodies which incorporate a focal plane shutter.
You can download a free user manual courtesy of the Norman Butkus website by clicking here.
I hope that my reply has been clear and useful, if so then please spare a moment to rate my answer.
Aug 02, 2011 | Hasselblad 553ELX Medium Format Camera
I pressed the shutter release button while attaching the lens to the body. Now my Hasselblad is jammed. The diaphram is closed, the shutter crank knob is turned about halfway, and the lens is stuck half...
On my Hasselblad 501 CM, I have never encountered this problem. As expensive as these cameras are, and delicate, I wouldn't chance it. I would contact the Hasselbad company and ask them to fix it for you.
http://www.hasselbladusa.com/service--support/technical-support/contact.aspx
I would try the above link to contact hasselblad's tech support if I were you.
Good luck on this.
Dec 25, 2010 | Hasselblad 501CM Medium Format Camera
Flash will not fire. Light indacts if fired, but no flash. Good contact and fresh batteries.
Hi Tam,
Try this:
Flash on
Flash ready.
Short out center pin to outside contact..this will fire the flash.
atdlee@netzero.com
Jan 12, 2010 | Sigma EF-500 DG ST (EO-ETTL II Canon) TTL...
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
I have a broken pot for CM 500.
I have a brand new carafe White for the Gevalia white for sale contact me elfnts@juno.com
Oct 27, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Need instruction manual
To download the instruction manual, please click on the link:
Gevalia CM-500 Manual
Sep 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Which Hasselblad?
There were several versions of the 500C/M as production was over many years. The 501C had all the latest revisions of the 500 C/M series to make it the better choice. You'll get more $ for the 501 for this reason. Later versions of the 500C/M had a much better coil spring to control the mirror for starters. Unless you are going to use this camera for daily professional use, either would be a reliable camera. A good way to check the amount of use on any Hasselblad is to look at the back of the camera where the film magazine mounts. A good solid black with no shiny spots on the plate would indicate little use. There are raised lines around the aux. shutter opening that will wear as film back are removed and replaced.
Nov 12, 2007 | Hasselblad 203FE Medium Format Camera
Cameras Logo
116 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
