Question about Refrigerators
Fridge stopped working loud pop\bang
I heard a loud popping sound in the kitchen, couldn't see anything obvious, then about an hour later it did it again. I opened fridge door, light wasn't on and fridge was not working. Pulled it out to unplug it and it did the same noise and my son's friend said he saw a blue flash through the crack in the door. The fridge has now been unplugged for 24 hours and I have just heard the same noise again. Can you tell me what you think it is?
  • jek8 Nov 16, 2008
    Yes,I do still need an answer but am on a tight budget and can't afford to pay for it, I was hoping someone would advise me so that if I needed to call out someone I could have an idea of the problem and not get ripped off. Can you help me if I can't pay?
  • TNGW1500SE Dec 17, 2008
    Mine does that too! Wish I knew what it was.
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
  • 1694 Answers
SOURCE: no picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Posted on Nov 02, 2007
  • 12 Answers
SOURCE: popping noises and no picture or sound
try replacing the stk's on the deflection board (making sure that all of the resistors on the board are OK and that there are no solder cracks I found one of the jumpers had a bad solder joint on the one I worked on) but if that doesn't fix I have some raw research that might give you somewhere to start :
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Posted on Dec 06, 2007
  • 5 Answers
SOURCE: microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Posted on Dec 14, 2007
  • 146 Answers
SOURCE: SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Posted on Dec 18, 2007
My car was off for 14 hours; I was standing beside it in the garage and a loud bang sound came from under the hood. I popped the hood and cannot see anything wrong. Am litle afraid to start it!! What
Is your car well protected with antifreeze? If not, maybe a freeze plug came out. Living in Montana, cars stay outside all winter. I always use a 50-50 solution of antifreeze. Never had coolant freeze up.
Before cranking the car, check that your timing belt did not pop. Don't know how it could, sitting there 14 hours, but turn crank slowly by hand, and check that camshaft is also turning.
Dec 29, 2012 | 2001 Chevrolet Cavalier
I have a nec computer which is often damaged . last month there was a sudden sound and the computer stopped working , i have cleaned the ram but nothing happened .later the computer showed lines on the...
1) Removed graphics card? Sounds like this is an NEC desktop computer, not laptop. 2) Loud pop? Have a look at this Vai,
http://capacitorlab.com/visible-failures/index.htm
See if one exploded.
(Those are Radial Aluminum Electrolytic Capacitors. They do pop. What REALLY makes a loud bang, is if a Solid Polymer Capacitor pops! Explode like a small grenade inside your computer case!
May not even see it anymore. Just a place on the motherboard where it was, and shrapnel from it all over inside the computer case.
When THEY pop, you KNOW it! )
Regards,
joecoolvette
Nov 26, 2012 | Computers & Internet
I heard a loud pop from car and then i couldn't steer it. When i got out fluid was running from it really fast
It sounds like you have blow a power steering line it sounds like the Pressure line as it would make a loud pop. There are two lines your pressure line and your return line. Check the pump so see if one of the lines is broken there if not it will have popped off at the steering rack. It could simply have a leak but that would not make the pop sound. The lines are relatively inexpensive and not really that hard to change. Hope that helps..
Aug 05, 2011 | Ford Escape Cars & Trucks
While oven was on, heard loud pop. oven no longer
Sounds like your element wire shorted out on back of unit.Try removing back panel and cheak wire on bake element .MAKE SURE YOU UNPLUG OR TURN OFF BREAKER.Hope this helped you out:)
Mar 11, 2010 | Kenmore Kitchen Ranges
Just got car fully serviced while driving a short time ago heard a loud bang .stopped the car and noticed steam comming from bonnet couldn.t see anything wrong
No coolant sprayed anyware?
it could be an air conditioner hose popped. Does your air condioner still get cold?
You should see traces of oil sprayed near the problem.
Nov 11, 2009 | 2000 Daewoo Lanos
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
2000 Diamante, Timing Belt ? Loud pop, explosion, bang...
sounds like the belt tensioner. look for any drive pulley that doesn't actually drive anything but is turned by the belt... that is spring loaded and keeps tension on the belt... if it moves freely... it needs to be replaced.
Mar 14, 2009 | 2000 Mitsubishi Diamante
Fridge intermittently bangs like very loud champagne cork popping
Sometimes when fridge first starts they can sound like water dripping into hot oil or deep fryer, this is caused by liquid refrigerant returning to compressor which has hot oil in sump, this is normal and no need for alarm, unless the fridge is not keeping temperature.
Nov 04, 2008 | Refrigerators
Refrigerators Logo
468 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
