Question about Car Audio & Video
Ford mondeo radio says locked
This happened after car battery went dead..i have now had the ignition on for over 2 hours,still says locked with a number 10 in bottom left of screen.
  • Anonymous Mar 12, 2014
    working fine with ignition off
If you know the code (which your Ford delaer will be able to give to you) then hold in 6 and it will allow you to put code in. Make sure you know the correct code though because if it gets to CODE 13 then you are stuffed!
Posted on May 27, 2009
  • 199 Answers
HI if you have the correct code, then pushing and holding the 6 button will give you one more attempt, if you enter the wrong code again, may as well put the radio in the bin .
make sure the code is correct!!
regards
Mark
www.carradiocode.co.uk
Posted on Nov 17, 2008
Hi
I think this will work, If the display shows LOCK10, turn on the radio whilst holding down 6 you can then enter the code.
Posted on Dec 01, 2008
Can anybody find me the radio code for, ford mondeo 6000cd RDS E-O-N Serial number being M112272
Need to see a dealer, to show proof of ownership
& give them your VIN # for radio code
Jul 17, 2012 | Ford Mondeo Cars & Trucks
I have a 2001 ford expediton 4.6 4wd..2 days ago I went to turn off my car and the radio and that beeping sound when the key is in the ignition when the door is open stayed on and wouldnt go off. I turned...
Not the Key but the ignition itself. Replace teh ignition module where the key is inserted to start the vehicle and that should resolve the issue.
Jul 11, 2011 | 2001 Ford Expedition
I have ford mondeo radio is 6006e model it doesnt turn off with key and when you turn on it says 1 hour before coming on how can i stop this please.
Have you been working on the wiring recently?
It looks as though the permanent battery feed( instead of the Ignition Battery feed) is connected to the Main battery lead in your radio....when it should be connected to the radio memory.
The 1 Hour means a wrong code has been entered
Jun 14, 2010 | Car Audio & Video
Code for a Ford Mondeo 6000cd radio
Hi Geof
Your radio code number should read: 5796.
I trust this will do the job.
I have no other code for your model.
Please let me know if this works.
Bye Ray
Sep 02, 2009 | 2001 Ford Focus
Ford Mondeo - ?Battery not getting charged after jump starting!
YOUR BATTERY SOUND LIKE ITS DEAD. CHECK BATTERY VOLTAGE SHOULD BE 12.5 VOLTS IF NOT TAKE IT TO YOUR NEAREST AUTO ZONE OR ADVANCE AUTO.LET THEM TEST IT LOAD TEST IT.WHEN BATTERY IS CHARGED OR REPLACED.WITH ENGINE RUNNING ALTERNATOR OUT PUT VOLTAGE SHOULD BE 13.5 VOLTS TO 14.5 VOLTS.IF NOT HAVE ALTERNATOR CHECKED.IF ALL GOOD YOUR ALTERNATOR FUSE / FUSE LINK BLOWED OR YOUR ALTERNATOR WIRES IS DAMAGE.OR DRIVE BELT SLIPPING.REMEMBER TO TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE.BATTERY CABLE.IF YOU DONT YOU WILL LOSE RADIO CODE.RADIO WILL NOT PLAY.
Aug 30, 2009 | 2002 Ford SVT Focus
2000 ford f250 w/ triton v-10 Battery drains within 1-2 hours of turning off ignition. have to disconnet the battery every time I stop the truck to avoid a dead b attery. Radio, power windows, etc all...
check glove box light if equiped, interior lights that no off when you close the doors, also some radio, cb, dvd, etc. if all good check alternator for possible drain
May 03, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Ford Mondeo Radio turns off when lights turned on. Returns later
Bad power connection: your radio loses power and turns itself off.
Jan 22, 2018 | Car Audio & Video
Auto door locking on Ford Mondeo
It sounds like it has been deactivated so we are going to reactivate the auto lock.
The numbers I will be saying will have to do with getting this to work so:
you will need to put the key in to the ignition switch.
1= is back to listen to the radio
2= is to get key out
3= is just before you start
4= is for starting your car
When we do this 1 and 4 will not be used
Do this and we will hope that it works like it should:
1: Turn the ignition with you key up to on( don't start)
2: Press the power door lock control 3 times
3: now turn the key back once (to off position)
4: Press the power door unlock control 3 times
5: ok turn the ignition back up 1 time. (The horn should chirp)
6: Then press the unlock control, then press the lock control, again (horn will chirp 1's) If auto lock
was activated.
7: Turn the ignition back 1's, Then the horn should chirp once to confirm the procedure was completed.
Nikki2913
Nov 23, 2008 | 2006 Ford Focus
Ford Mondeo car radio is locked
The dealer needs to help you with this. This is part of the theft protection system built into many new cars. In most cases, only the dealer can turn it back on.
Dec 21, 2007 | Car Audio & Video
Car Audio & Video Logo
1,278 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
