Question about Cambridge Soundworks 740I CD Player
Discs stuck inside CD Player. Screen says ''Reading.''
Screen says "reading." When I try to press the open button to retreive the CDs, the screen says "open," but the door does not open, and none of the CDs will play. The FM, Aux, and Tape decks work fine.
  • jaudio May 22, 2009
    CD does not properly eject. May come part way out and immediately go back in and play. May pause half-way out, and can be grabbed and pulled out. It does complain when I do that.
  • 3 Answers
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Posted on Mar 16, 2009
I have a panasonic sa ak15 stereo system, the five cd trays have cds in them, i pressed the cd open button but cds don`t come out, the system screen says change, what could be the problem?
The door loader motor isn't working. Sometimes the plastic tray warps and hangs a bit. Mine still hangs, but I can give it a push to close. If you can see the door trying to open you can help it open but you have to be quick or you have to press the open button more that once.
Feb 24, 2015 | Panasonic Audio Players & Recorders
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
The door won't open and the screen says illegal open
try sliding the door by hand to the right. If you can slide if, lift up on the left side while sliding it all the way to the right and the doot should slide off. Then try sliding it back on. One of the door switches is probably out of place and just needs to be realigned.
Nov 06, 2013 | Panasonic SC-HC30 Audio Shelf System
When i turn the page on the sony ready touch I can still see the last page under the next page. Has this happened to anyone else?
Hi patsyhodgins!
At certain point this "goshting" you see its normal operation because of the type of screen (E-Ink) but if you get words mixed or its too difficul to read, you can try a reset:
Note: This will not affect your ebooks:
1. Disconnect the reader from the computer
2. Power off you reader
3. Hit the reset at the bottom for 3 seconds
4. Power on you reader
5. The screen will blink and will display "Opening Book", let the reader load your books
See if the problem persist, if so, you can try a hard reset, make sure the reader is fully charged.
Note: This will delete all content from you reader, I recommend you to back uo your data before proceed:
1. Power off the Reader.
2. Press the RESET button.
3. Power ON the Reader.
4. When the screen shows "Opening book..." , press and hold at the same time the "Page Back" button and the Volume + at the bottom until the "Reset All" appears on the screen
If none of the steps above work, then contact Sony to get the screen repaired.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 17, 2011 | Sony Reader Touch PRS-600
How to change drum to a Brother Super G3 Fax Machine instruction state to change drum, and with door open, hit the clear button until "Replace Drum?" appears, then hit 1,,,,,,well there is no...
With door open, press "Options." Screen reads, "Change Drum?" Press 1 for yes. Screen reads "Accepted." Place drum/toner in, close door. Done!
Feb 03, 2011 | Brother IntelliFax-2920 Fax
Breadman TR875 powers up but none of the buttons seem to
After powering it up, press and hold the start button (these are instructions from customer service). On a good machine this doesn't seem to reset anything. If this doesn't work, try holding in the start button while you plug it in and than release after a few seconds.
Jan 17, 2010 | Breadman TR875 Bread Maker
Electric Range Model Number: FEF365CGBD> The oven door is open and the lock is engaged. The lock light is flashing. I tried disconnecting power (from the main breaker) for about 10 minutes but that...
. If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open.
hold in the door button and push broil until the latch makes a 360 degree
then the door lock should stop flashing and the oven will work again .
Hold the lock button for 3-5 seconds..
if the door was open but the lock are latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button pressed for 10-15 seconds, at which point "locked" appears in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlock the unit.
if still the same problem the door assembly is cracked and that needs replacement.you can get required parts
from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 17, 2010 | Kitchen Ranges
When i press cd on my radio it constantly says reading on the screen but no sound is coming out.i have a classic beetle and it needs music
The problem normally is to the reading head. You have to open the player find the head and clean it with a cotton stick very gently. Then try to listen a cd. If it works it's ok, or else your head is broken and you have to replace it thing that I am not suggesting because of the high cost of the head.
Oct 07, 2009 | Kenwood KDC-C667 6-Disc CD Changer
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Cambridge Soundworks 740I CD Player Logo
683 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
