Question about Maytag MMC5000 Microwave Oven
Maytag microwave 5000
Turntable does not turn
  • Maytag Master
  • 9,098 Answers
In some cases, the unit will have an option to turn the turntalbe on and off, depending on your needs. If you have your manual, check there to see if that optyion exists, and if so, you should be able to use the HELP or other key to turn it on. If not, you can visit http://www.maytag.com and select the use & care manuals option near the lower right of their home page. You will be instructed to enter your full 10-digit model number. Then you can download it. If that doesn't solve your situation, then you may have a bad connection, a bad switch or relay on the control panel, or a bad motor. Once you've checked against the manual, please feel free to post back with your full model number and we'll be happy to help you further.
Posted on Nov 25, 2006
Maytag microwave turntable doesn't operate
Does everything else work?? If so, its just the turntable motor, simple to replace. there are three or four screws under the bottom. UNPLUG the microwave first.
Double check before ordering...but ..
Here is the one you need:
Turntable Motor DE31 10172C
Oct 01, 2017 | Maytag Microwave Ovens
My microwave turns on, turntable turns, just won't heat. the microwave is 6 years old. Is it wiser to bring in a repairman or just replace? there is a picture of the microwave by the timer window.
There are 2 fuses inside the cabinet. One is for the clock and turntable. The other is for the high voltage transformer and the microwave module. If this fuse is blown either the transformer is shorted or the module has failed to cause the fuse to blow. Parts and Labor can get close to the cost of a new one, so get an estimate so you can have information to make your decision
Nov 09, 2017 | Maytag MMV4205 Microwave Oven
Turntable will not qwork
The turntable motor is defective and must be replaced, I suggest contacting the Maytag people for service.
Jan 26, 2011 | Maytag MMV5208W Microwave Oven
The turntable in the microwave won't turn at all. Unit is <1 yr old. The turntable on/off selector doesn't help it. Any suggestions?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | Maytag MMV4203D Microwave Oven
Microwave will not heat. The light comes on the turntable turns
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Microwave Turntable doesn't spin
Hi
Sounds like the turntable motor has packed up.
Normally this is located underneath the microwave and should be readily available as a spare part.
BE WARNED i would NOT suggest taking the cover of the machine. There is a capacitor in there which stores 5000 volt and if you dont know what you are doing it can kill.
Please leave feedback
Rob
Feb 12, 2009 | Microwave Ovens
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Over the range microwave turntable has stopped turning
You give very little information Toni, but it seems the turntable motor is defective. If you are comfortable with this you must remove the cabinet (probably six screws in the back) and locate the motor at the bottom of the unit. Check all connections and connect the motor to a 120 volt source. If it is defective, order a new one on-line from the manufacturer. Your other option is to replace the oven. This would be my suggestion unless it is still in warranty.
Ray
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Maytag MMC5000 Microwave Oven Logo
63 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
