Question about Sharp XL-HP737 CD Shelf System
Cd case will not open
I think one of the cd's came out of drawer and slots won't open?
  • 12 Answers
If you're really brave, unplug the unit and remove the case screws. Pop off the case and get your CD back. The you might need a draw belt. See prbline.com or studiosoundelectronics.com
Posted on Nov 15, 2008
Cd drawers won't open, may have cd stuck in #1 slot
How to Fix a stuck CD Tray - YouTube
? 6:24
https://www.youtube.com/watch?v=gpvjqATX3Rs
Mar 24, 2010 - Uploaded by Guy Techie
Pin won't open my tray :( Help please?. Read more ... I was lucky to find a rubber band in my junk drawer and it ...
When a CD or DVD is stuck or the drive won't open ' PCWorld
Dec 09, 2015 | Audio Players & Recorders
Denon CD Player Drawer won't open
This problem can be due to a defect in the player mechanism or binding in the drawer travel path. You may be able to find and correct the binding problem.
Jan 29, 2015 | Denon Audio Players & Recorders
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
National Semiconductor data checker model 1800 how to open cash door
There is a square slot on the bottom of the cash register. Near the back center. Inside that square slot if a manual drawer release mechanism. Push on that mechanism with your finger or a small object and the drawer will open.
Jul 06, 2012 | Optics
HP Z1 WORKSTATION WON'T EJECT CD
Make sure the computer is turned on then Take a Paper Clip (Gem Clip) and straighten it out then kneel in front of the desktop facing the cd drawer. Look closely at the drawer and you will see tiny hole where you will insert the paper clip (Gem Clip) and at the same time Press the Button on the cd drawer while applying pressure by pushing the paper clip (Gem Clip). The drawer will pop open. Don't worry about breaking something, that's why that tiny hole is there.
Jun 02, 2012 | Computers & Internet
CD won't eject from laptop
Open up a paperclip so you have a couple of inches of straight wire. Take the USB stick out if possible. Find the little hole on the cd tray and gently push the paperclip in there,straight in. With luck, it'll click, and the CD drawer will open a lilbit, enough that you can grab it and gently pull it out. Do what you need to do, then close the drawer and put the USB stick back.
The keyword here is GENTLY, use only as much force as you must to get the drawer open. Be careful, but they're made with this unlocking feature for a reason. Good luck!
May 08, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a Phillips model 601/25 CD player and the CD drawer won't open - it makes a whirring noise but refuses to open.\r\n J A Adamson <jadamson35@gmail.com>
The rubber band has stretched with age. Easy fix, take cover off (several screws around the case) and band is easily accessed. Even a cheap elastic band will work as a replacement for now, it only opens the drawer mechanism, no effect on sound quality.
Aug 20, 2011 | Philips Audio Players & Recorders
I was putting CDs in my Philips 3-CD Player and
The best solution is to open the case and manually remove/realign the jammed cd.
Mar 13, 2009 | Philips Audio Players & Recorders
Home cd player will not open
Look underneath the unit for an access hole . It may be labeled as such.
Some CD units offer a manual drawer open device under there.
May 16, 2008 | Yamaha CDC-565 5-Disc CD Changer
Sharp XL-HP737 CD Shelf System Logo
82 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
