Question about Sony XT-100HD HD Radio Tuner
When battery is disconnected ''on state'' and memory is lost.
Is there a way to force the XT-100HD to remember the FM channel of my choice so that when the battery is disconnected it will remember that frequency and return to the channel of my choice after power is restored?
I see from schematic that there is a connector inside the cover (cn501) which is labeled "Flash Programming". This connector has pins labeled RX, TX, Flash_W and 3.3v_backup. May this connector be used to change the default functionality if this unit to force it to return to "radio on" state and on the frequency I have preselected?
Thank you!
    Problem Solver:
  • 5 Answers
There actually is the capability that come with very few radios right now. But, you are looking at a lot of money. I like sticking with my $130.00 Kenwood that plays cd's, fm and am radio, a aux. output to hook my comuteror ipod up to, but my favorite feature is a USB port to hookup a flashdrive to it. I can put thousands of songs on my 12gig. flashdrive and never have to worry about the radio again, including never having to worry about having to reset the stations after disconnecting the power supply.
Posted on Jun 26, 2009
  • 20 Answers
Sorry but as soon as you disconnect your battery you will lose all memory to everything including your station presets,just as you would your in car l,e,d clock if you have one,,and from what i know i dont think theres a unit that has that capability yet,,hope that helps,,goodluck.
Posted on Dec 01, 2008
My roady xt does not have a fm select option on the menu
You need to have it in the AUTO base/cradle - AND - you cannot have anything plugged into the LINE OUT or AUX OUT jack, as it will disable the FM transmitter. Try unplugging the audio output, then you'll be able to select the FM transmitter again. I believe that they removed the option from the HOME cradle/dock all together because of regular AM/FM radio stations complaining to the FCC that the transmitters were too strong (in other words, they wanted to hurt satellite radio competition or slow it down as much as possible by forcing Sirius and XM go back and redesign their radios for a much weaker or NO FM transmitter).
Nov 07, 2010 | Delphi Roady XT XM Radio Receiver
After installation I have no signal.
Make sure the antenna is in the clear to allow it to "see" the satellite signals....
Feb 15, 2010 | Sony XT-100HD Satellite Radio Receiver
I changed th ecar battery and the memory of the ndcn-w54 cd player is lost
i replace a battery for my car.Now dncn-w54 cd player asking "insert correct map disk" please assist me to solve this problem.
Feb 06, 2010 | Car Audio & Video
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
Where do the 3 wires in back of my Cobra18wxst11 go? Can I use a cigarette lighter plug?
From www.Cobra.com
"Where do I connect the three power wires? (radios with 3 power leads)
Answer: Connect the black wire to chassis ground.
Connect the red wire to a switched +12 volt source, such as the fuse for the AM/FM radio.
The orange wire is for the memory retention of your CB radio, and should be connected to a constant +12 volt source. The fuse for the brake lights is usually a good choice.
With the radio wired as above, the radio will turn off when the ignition is turned off. The orange wire will provide power to the radio so that it remembers the channel.
If you are installing your Cobra CB radio in an application where you wish to utilize a cigarette plug to power the unit, connect the black wire to the negative lead (side terminal) on the plug. Connect both the red and orange wires together to the positive lead (center tip) of the plug. Your unit will function properly this way but will not retain the channel memory. When power is applied your radio will come up on channel 9."
Oct 23, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
How do I access the songs that are in the memory of my Roady XT?
I doesn't save the songs, only the song title information. Go to MENU and you can see there is a selection to it to show the 'memory' listing -again, it is only the channel, artist and title info to remind you the name so you can buy it. some also have the tunealert feature so that the radio beeps when your favorite is on another channel.
Aug 20, 2009 | Delphi Roady XT XM Radio Receiver
My RoadyXT forgets what channel it was set to when I turn it off for more than a few minutes. It remembers if I'm only moving it from one vehicle to another, but when I turn it off overnight, it comes on...
No battery. Always turn it off with the POWER switch, not just pulling the plug on the radio or taking it ouf out it's base. Using the POWER switch, then it will remember for a little while.
Aug 13, 2009 | Delphi Roady XT XM Radio Receiver
I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
I have the manual.
1. Press the FUNCTION button to select FM or AM mode
2. Press SKIP to select station.
3> Press and hold the Memory button to enter channel saving mode.
4. Press the Memory button to select desire preset channel #.
5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
6. Repeat step 2 and 5 to store addtl. stations.
Any idea as to how to set the volume during alarm mode, it's too loud!!
Jun 04, 2009 | Audio Players & Recorders
Channel memory
this t5v is a piece of ****
Oct 20, 2007 | Niko OTP-2613W 26 in. LCD Television
XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Sony XT-100HD HD Radio Tuner Logo
181 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
