Question about Dryers
Drum has dropped (indesit is70) - Dryers
  • colonel5 Nov 15, 2008
    ta bob, there's something missing off the end of drum spindle, i've found a washer, colonel5
  • 833 Answers
Sounds like the support wheels for the drum or related parts have broken.  You'll have to get in there to see what broke and replace it.
Posted on Nov 15, 2008
I have an indesit IS70 SC tumble dryer which is very noisy. The noise appears to be coming from the air intake fan and sounds a bit like a piece of cardboard against bicycle wheel spokes. Any ideas?
Dryers are not hard to take apart.
There is possible something caught inbehind things.
Make sure to unplug the dryer first. Then proceed to take it apart carefully noteing thing as you do it, so that you can reasseblem
Jan 12, 2013 | Indesit IS70C Electric Dryer
Remove bearing from indesit drum how to split drum
all of the newer indesit washing machines have whats called a welded drum meaning they cannot be split open.the thing about this is to change the bearings you have to buy a full drum. best option is to go through the indesit company themselves. aprox cost £100 if under 5 years and £140 if over 5years. hope this helps
Jun 19, 2011 | Washing Machines
Too much water going into the machine indesit wil103 water coming out the drawer when the drum turns.
Could try pressure switch/ clean the pipe feeding it check for hole in it causing air leak and pressure drop, make fill valve overfill
Apr 20, 2010 | Indesit W 123 Front Load Washer
My Indesit IS70 tumble dryer is not venting properly. Water build up in the base of the machione, behind the condenser, and does not make its way to the water holder at the top of the machine.
there is a hole for the water from the condensor to the water collector. make sure it is not blocked - this is common to happen.
take small panel off at back of machine and you can see the water collector. it has a small pump mounted on it which takes the water up to the top of the machine.
connbect this pump independently to mains and make sure it is pumping
Oct 14, 2008 | Dryers
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit is70 tumble dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 06, 2008 | Indesit WA 125 Front Load Washer
Indesit wd 12 drum
please rephrase your question as what you are explaining does'nt make sense
Feb 14, 2008 | Indesit W 123 Front Load Washer
Wm12x drum stopped
It's probably the bearings. The drum have probably get so loose from the bearing, so the belt have snapped off.
Jan 28, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine w 123 front load
You have to get to it somehow. Get two metal strips & just join the blocks by drilling and screwing.
Dec 19, 2007 | Indesit W 123 Front Load Washer
Dryers Logo
93 people viewed this question
Top Dryers Experts
