Pacific 900 dvd player not responding. Both power (green) and standbye (red) lights on.
SOURCE: Sansui SAN0901 DVD Recorder - Power Problem
Hi Pandjoy,
I have been struggling with the same problem and almost rebuilt the power supply before finding the solution. In my case it was a faulty capacitor-C4, next to the diode D4. Replacing C4 and the machine performed as new. I hope this helps. Cheers
SteveO
Posted on Jan 10, 2008
SOURCE: pacific dvd player
No Joy yet. Sounds like the disc won't spin up to the proper speed, or something else during it's initial startup slf-checks, so it just wets the bed.
Posted on Mar 05, 2008
  • 4 Answers
SOURCE: GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Posted on Mar 25, 2009
jtd866
  • 71 Answers
SOURCE: My dvd player will not turn on. It powers green
try to check some capacitor at the power supply
Posted on Aug 29, 2009
jdvillanueva
  • 2098 Answers
SOURCE: DVD player will not recognize any DVDs I put into
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
Since you've already done the #1 now proceed to #2.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I
Posted on Jan 24, 2011
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Does not provide code for my pacific dvd player
You can perform a manual search.
Press and hold TV,SAT,DVD or VCR until the centre light blinks red.
While it is blinking press 0000
The flashing will speed up.
Press the power button repeatedly - it will cycle through all codes.
When your device turns off (powers off) press the okay button.
It should now power on and off correctly.
Check the other buttons to see if everything works.
If it does not start the process again - it will hit another code which will also power down the device - takes a long time but should work - manual states it may take 20 mins - practise says longer!
May 16, 2009 | Pacific Digital PRIMEVIEW801 Video...
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
CyberHome DVD player not responding...
The internal power supply has failed and is shutting down each time you try to turn it on. To remove your DVD there is a slot on the bottom labeled: Emergency.... with an arrow pointing the direction you need to push a lever to open the drawer. With good lighting you'll see the tab you need to slide over. Use a small flat blade screwdriver and the drawer will open enough to grasp it and pull it open. The power supply will need to be repaired, but it may have caused other damage and may be more expensive than buying a new player.
Mar 06, 2008 | Cyberhome CH-DVD 300 DVD Player
Non responsive dvd600 by Oritron
Can you take led off, see if DVD stuck inside unit? Find the tray release button and manually open the tray and replug. and see if unit respond.
Aug 10, 2007 | Oritron DVD600 DVD Player
Coby 626 DVD Player Remote Not Working
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
Mar 18, 2007 | Coby DVD-224 DVD Player
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
