Question about Canon NP 7130 Black and White Copier
Don´t show a copy,
I havve a canon NP7130, its don´t show copy, the page out in white
  • Anonymous Mar 23, 2014
    White showing on one side
  • 92 Answers
Try to change cartridge.
Posted on Dec 23, 2008
Copy machine - canon PC920 leaves black streak in middle of page - on copy
Check for white-out or some other dirt on the scanner head, the piece that moves from top to bottom to scan the item to be copied.
Feb 18, 2017 | Canon PC-920 Black and White Copier
I need a service manual for an Canon np7130
I found a service manual for this model. If still need it let me know.
Apr 08, 2009 | Canon NP 7130 Black and White Copier
The start key does not stop its cycle
Control panel definitely needs replacement. Based on the age of the unit and the cost (at least $350) of the repair, I would recomend replacement.
Nov 10, 2008 | Canon NP 7130 Black and White Copier
Canon np7130 copier
Most likely when you make a copy you don't see the light scanning the paper, you can try this with the lid open to make sure. the Sacnning lamp is blown, need to replace
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Black Copies
It could be a bad voltage board, which is not supplying enough power to the lamp.
Jun 30, 2008 | Canon NP 7130 Black and White Copier
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Canon NP7130 copier
Make sure that the black plastic arm just to the right of the gray drum release handle is in the proper position. This arm sometimes gets knocked out of position when engaging the tube of new toner. When the copier is clammed closed, this will sometimes come down on the right side of the post on the bottom front cover. This will move the developer far enough away from the drum to make blank copies. Hope this helps.
Nov 12, 2007 | Canon NP 7130 Black and White Copier
Replace drum
hi im the packaging of the drum has a instruction that will show you the process in replacing he drum or just open the front door of the copier the drum unit has a lock for you to lit up just a small lever or 2 lever.after that you can easily full out the drum.just remember just dont let the drum before be expose to light it is sensitve to mit.5minutes is enough time for it to be expose morethan that the drum becomes deffective
Nov 05, 2007 | Canon NP 7130 Black and White Copier
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon NP 7130 Black and White Copier Logo
64 people viewed this question
old marine
old marine
