Question about Whirlpool LSR5132PQ Top Load Washer
Washing machine keeps filling does not stop...
Is it worth fixing....it is 5 years old
  • 370 Answers
You probably have a bad pressure switch. That should fix it. The pressure switch is under the control panel.
Posted on Nov 18, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Hotpoint Washing machine keeps flooding kitchen
For the age of it, you can either replace it or get it fixed. I would personally get a quote first for repair.
May 18, 2012 | Hotpoint Aquarius WT540 Front
Spin cycle does not work. Machine only hums when it should spin.
Check the motor capacitors. Wash cycle and run cycle capacitors are different in some m/cs.If these are OK motor winding to be checked.
Now it is ten years old and you are likely to get ball bearing problem. Get an repair estimate and decide which suits your budget.
Apr 06, 2010 | GE WBSE3120B Top Load Washer
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Admiral lnc6760b71 Problems - Strong smell of burning plastic or rubber last week. Now the machine will stop when full of water and not respond. Later it will continue by itself. I took of a small panel...
Same problem, same model admiral. The smell is motor overheating. Once cool enough, it will continue with it's cycle. I took the top off and watched it run. The motor stopped and smoke rose from the motor located at the front right corner. I am scrapping mine and buying another washing machine. This admiral has been trouble since we bought it 5 years ago.
Jul 11, 2009 | Washing Machines
Washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Nov 18, 2008 | KitchenAid KAWS750L Top Load Washer
Drum filling with dirty water
hi as your machine got a non return valve on it to stop water from getting into your machine via waste pipe. worst case is call indesit as i am sure you now get 5 years parts g/tee as indesit is now part of hotpoint still cheaper than another machine hope this helps
Jul 11, 2008 | Indesit W 123 Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
