Question about Frigidaire FEQ1442ES Electric Dryer
Beeping Lights I recently got back from vacation only to find my dryer beeping and lights flashing. I have a warranty so I called the repair man out. They took it apart and checked everything. Of course, it was fine and wasn't exhibiting the problem anymore. They could not find anything wrong with it. The next day, I woke up to a beeping dryer and lights flashing. I hadn't even used it! Can you give me possibilities of what it could be?? beeping and flashing lights
There is way to find out what error codes the dryer may have and that may suggest a what part may be the problem
Posted on Jan 15, 2009
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dle2701v beeping flashing lights
It may be solve problem or maybe your dryer have some problem with motor also
The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary .
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | LG Dryers
My dryer was working of I have to say never really has dried as well as I thought it should but it was at least working. However now it will not turn on at all. It was at first just beeping and all the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Fridgidaire dryer beeping and flashing lights
Download the troubleshooting instruction sheet here ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134509400efs.pdf
Follow the instructions and reply back what you determine and I will help further.
Jan 28, 2009 | Dryers
Not sure
Do you get a flashing ABS light or BRAKE light along with the beeps? If so, this is indicative of an ABS failure, which is either a wheel speed sensor or (much more likely) the ABS controller. I've had an ABS/wheel speed sensor fail on my A4 and I had no beeping, but people I know have had the beeps and had to replace or rebuild the ABS module. If you do have this problem, go to www.modulemaster.com and call them - they can rebuild the ABS module for a couple hundred dollars give or take, versus several times that cost for a new one.
If you are only getting the beeping, but not the lights flashing, it could still indicate this failure, but Audi usually has the cars set up to indicate what is wrong by flashing lights as well as the beeping, to help you see what the problem is.
Jun 23, 2008 | 1999 Audi A6
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
671 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
