Question about GE Profile PDW8400J Built-in Dishwasher
Buttons won't work on GE Profile PDW7980N10SS
None of the buttons respond to my 14 month old dishwasher! The normal cycle and the heated dry button lights are on but none of the buttons on the panel give any response. I've turned off the power to the dishwasher in an effort to reset the machine to no avail.
  • 1 more comment
  • Anonymous Feb 28, 2009
    I tried this and it still does not work.   the time says 1 hour and I can not reset it.  Any solutions?  thanks
  • Anonymous Mar 01, 2009
    I have the exact same problem with the control panel not working and the heated dry light was on with the "normal" light. Has anyone figured this out?
  • Anonymous Mar 30, 2014
    I turn off and on the cricut breaker to the washer hoping it would reset. but nothing.
    Scholar:
  • 111 Answers
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
    New Friend:
No, pressing the heated dry button for 5 secs.. Or doing the sequence "heated dry, normal, heated dry, normal dry" does not work! Any other suggestions???
Posted on Nov 25, 2012
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Press to start-nothing happens-no buttons pushed respond
IN MY CASE, IT WAS THE "HEAT DRY" PAD. THE CONTROLS WERE LOCKED INADVERTANTLY. NEED TO PRESS AND HOLD FOR THREE SECONDS TO UNLOCK. I FOUND THE INSTRUCTIONS ON THE WEB.
Apr 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
AMANA ADB1500AWQ Control buttons not working properly. Will not allow selection of wash cycle or heated dry. Occasionally the controls are completely dead, and none of the lights light up. This...
unplug the power cable from wall socket.check the voltage from the household receptacle to the dishwasher, volt meter.It might be your neutral line is bad,or the console is bad
Jul 23, 2008 | Amana Dishwashers
Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
The part is covered by warranty. However, the labor is not and Whirlpool will not replace the part without having someone service the unit. Every place I checked wanted $100 just to come out and tell me what was wrong. Any service would be extra. Seems like Whirlpool figured out how not to stand behind its products. They should be held accountable.
Dec 27, 2006 | Whirlpool 24 in. GU2500 XTP Built-in...
GE Profile PDW8400J Built-in Dishwasher Logo
1,501 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
