Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Remaining unanswered questions
Is this something I can do myself? How do I know which it is...bulb or light engine?
  • louconner Nov 21, 2008
    I decided to start with the bulb replacement rather than the engine...I can see that is something I should leave to the pros.....Received the bulb........but can't get it out of the bulb "cage"...it is stuck on one corner.......should I force it????
    Thanks
  • 101 Answers
Its not a cheap fix, as the part alone costs over 300usd I would leave it to a professional myself.
Posted on Nov 15, 2008
How wiring diagram for christmas lights work
All the bulbs in a section of lights are connected in series, meaning one after the other, like links in a chain. If one bulb goes out the chain is broken and that section goes out. All modern light sets have bulbs which have a built-in feature called a shunt. The shunt in the bulb is supposed to short out if the bulb filament burns out. The advertising wording would be something like 'if one bulb burns out, the others stay lit'. It usually works, but there are limits. Sometimes the shunt in the burned-out bulb fails to work and the chain remains broken. You have to find the bad bulb and replace it. Also, every time a bulb burns out, if the shunt is working and the other bulbs stay on, the power to each remaining lit bulb increases. This puts a strain on the remaining bulbs, which is why you should always replace burned out bulbs as soon as you discover them. If you don't and more bulbs in the same section burn out, you can reach a point where there's too much power for the remaining bulbs to handle, and all (or at least many) of the remaining bulbs will burn out, necessitating a replacement of the string.
Dec 15, 2011 | Christmas Lights Etc Santa's Toy Truck
I have just done my oil and filter service in the garage. The mechanic forgot to reset the service light. I did it myself acc to this forum suggestions. However, when I check the remaining km status on the...
TO RESET, MOST VEHICLES TURN ON THE IGNITION SWITCH, [DO NOT START THE ENGINE ] PRESS THE GAS PEDAL TO THE FLOOR 3 TIMES, THE LIGHT SHOULD GO OUT. IF THAT DOESN'T WORK, YOU CAN DISCONNECT THE NEG. BATTERY CABLE FOR A MINUTE THEN RECONNECT, START THE ENGINE, THE LIGHT SHOULD BE OUT
Dec 25, 2010 | 2006 Audi A4
Broke need to replace myself, need diagram for 2003 Impala
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/2003/make/chevrolet/model/impala/2003_chevrolet_impala_drive_belt_routing_diagram.htm
Feb 01, 2010 | 2003 Chevrolet Impala
Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Mar 04, 2009 | Whirlpool Refrigerators
I have a slide dimmer switch The orange light on the switch plate is flickering, when slid down in the off position?
This is caused by the neon bulb that is used in most slide dimmer switches, it is normal and doesn't mean anything is wrong with your dimmer. The flickering is because the neon bulb doesn't have the usual filament, but used neon gas to cause the light to glow.
The bulb is used as a locater light for nightime so you can more easily find the switch in the dark. When the light switch is turned on, the neon bulb typically isn't lit.
Hope you find this Very Helpful and best regards!
PS: I just came across this unanswered question and decided to provide an answer to clear this unsolved question from the site.
Feb 25, 2009 | Electrical Supplies
Missing wire clamp on lamp housing.
Well, I fixed it myself. I used a wire hanger, measured and cut a portion off, bent it in a shape that fit in the housing and around the light bulb. Turned out pretty nice if I do say so myself. TV is working fine and dandy now! =)
Sep 08, 2008 | Sharp 56DR650 56" Rear Projection HDTV
I need to replace the bulb in my TV. Is this something I can do myself?
Hi meggmassey,
Since your post does not include your model, the answer to your question includes a little bit of research on your part.
Because televisions which use bulbs require periodic bulb replacement (simply because of the nature of a light bulb), some manufacturers have made the light bulb serviceable by the consumer. Often this is done by having the bulb in a housing that is simple to replace, typically accessible without accessing the rest of the internal parts.
To find out if this is the case with your television, I recommend consulting your owner’s manual or calling the manufacturer’s product support line.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 27, 2008 | Televison & Video
Back up lights
pull out the bulbs put ur car in reverse without the engine running and the key switch on and check for 12 volts at the bulb plugs if no voltage check for a blown fuse
Jun 16, 2008 | 1999 Pontiac Sunfire
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
