Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Black screen and numbers 2 and 4 lit
When I start up my computer, it shows that windows is supposed to star and then the screen goes black, and on the lEDS on the pc the numbers 2 and 4 stay permanently lit. Nothing happens. What can the problem be and how can iy be fixed?
  • o_corredor Nov 16, 2008
    I tried starting my computer in safe mode but now it shows a message in a blue screen saying:
    "A problem has been detected and windows has been shutdown to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, please follow these steps:
    Disable or disinstall any antivirus, disk defragmentation, or backup utilities. Check your hard drive configuration and for any updated drivers. Run CHKDSK/F to checkfor hard drive corruption, and then restart your computer.
    Technical Information:
    ** STOP: 0X00000024 (0X00190203,0X86A17820,0XC0000102,0X00000000)
    How can I fix this problem? The computer screen and the pc stay still from this point on, and nothing happens.
  • Dell Master
  • 998 Answers
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 16, 2008
  • Walter H Boehm Nov 16, 2008
    A blue screen with the error code (STOP 0x00000024) can be caused by a damaged file system. Your Windows software is corrupted or the hard disk drive has a problem. Do you have any CD’s that came with your computer? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your computer and tap the key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit key. Select the “Run the 32 Bit Dell Diagnostics”. Next select the “Express Test” and see if any errors are detected. If no errors are reported, then your operating system software is probably the culprit and you will have to reinstall Windows.
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Everything that is supposed to be black is showing
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Televison & Video
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen is Black/Not on from start.
Try going into your BIOS by starting the notebook and tapping F10, when the screen comes up then tap once on F9, and choose to save default settings, and tap F10 again and exit. One other thing you can try is to connect your notebook to another screen or another PC so that you can see it is your video card or your screen. If you are having problems with your video card it will not show up on an external screen either, but if its your screen then you should be able to get video on another screen. If you do not get a screen in the BIOS screen then I would go to Radio Shack and have your video card tested.
May 31, 2009 | HP Pavilion dv1000 Notebook
Windows starts to set up then screen goes black and
9 times out of 10, the finger points to the power supply.
Replace it and try again - I reckon you'll be good to go!
Apr 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Screen is blank or black
it maybe sounds a little like a problem in explorer.
try to start you computer up, press F8 within the windows loader appears. then select :start up the same way as last time it worked.
now it should work. if not then format the pc.
if you have a lot of important stuff on it you can download the ubuntu livecd and use it the get all of your stuff out of the disk.
hope that works.
CS.
May 15, 2008 | IBM ThinkPad A21m 2628 Notebook
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
251 people viewed this question
Alun Cox
