Question about kawasaki Sport & Outdoor - Others
Head bolts torque and sequence
Head bolts torque
head bolts torque pattern
    Problem Solver:
They are listed in all Chilton Repair books,available at any auto store
Posted on Nov 30, 2008
How can I find torquing sequence for a 10 bolt 85 MIT 2.6 motor
Try this friend,
MOST cars have the save pattern of sequence It isnt an EXACT requirement. !!! You wont distort the head if you follow the below
10 Bolt mitsi
http://www.schematicsdiagram.com/2012/10/cylinder-head-torque-setting.html
Sep 13, 2014 | Cars & Trucks
Head bolts torque sequence on Briggs & Stratton model number 331877
If you don't have the proper sequence then the general rule is to do a cross pattern. Do one bolt on your left then one on your right then left etc. When torqueing head bolts you need to torque in three stages. figure out your torque spec then divide by three. That # is your first torque. Do all bolts to this and then do the second torque then the last torque which should be the f/lbs you need to be at
Jul 27, 2014 | Garden
What is cylinder head torque and sequence ?
torque to yield bolts only good for one use. torque pattern will always be from the inside out working in a circle pattern replace the head bolts ask your parts guy the torque yield spec.
Jun 04, 2014 | 2010 Toyota Yaris
Head bolts pattern
torque? on and off , sequence?
there are head bolt seq. and cam cap seq,
and more. in the fsm. page 1D-45
1st remove seq.
now , install sequence.
log in to alldata.com and see all the other details, on engine
assembly, the warnings, and special details.
May 13, 2014 | 2002 Suzuki XL-7
Head torque and pattern
The S-10 had two (2) different head bolts, a long bolt and a short one . The torque on the long one is 46ft./lbs. and an additional 90 degrees . The short one is 43ft./lbs. and an additional 90 degrees .
Looking at the head from the front of the vehicle, follow this torque sequence :
Start with the center bolt on the passengers side (left side of the head), followed by the center bolt on the drivers side (right side of the head) . Then torque the bolt behind the center bolt on the passengr side . Next torque the bolt in front of the center bolt on the drivers side . Then torque the bolt behind the center bolt on the drivers side . Next torque the bolt in front of the center bolt on the passeger side . The torque the last bolt on the drivers side, followed by the front bolt on the passenger side, followed by the last bolt on the passenger side, and lastly, the front bolt on the drivers side .
Aug 24, 2012 | Chevrolet S 10 Cars & Trucks
Can't find the torque head bolt pattern for a 1996 gmc sierra 5.7 vortex
The "pattern" for ANY cylinder head is pretty much the same...start with the bolts in the center of the head and work your way out to both ends.
Torquing the cylinder head on your 5.7L Vortec engine to manufacturer specifications requires the use of a "torque angle" gauge, as well as a traditional torque meter.
The torque specifications are as follows:
> Step 1: All bolts: 22 Ft Lbs (30 Nm.)
> Step 2: Short bolts: Additional 55 degrees; Medium bolts: Additional 65 degrees; Long bolts: Additional 75 degrees
May 20, 2012 | GMC Sierra 1500 Cars & Trucks
Head Torque 4.3
Before i give the steps and spec make sure the head bolt threads are clean and oiled. Also the image link (click the word link) is the pattern you must follow to torque the head bolts correctly, I will also post the image below.
Head bolt torque sequence:
First Pass In Sequence - 26 ft-lbs
Second Pass In Sequence - 44 ft-lbs
Final Pass In Sequence - 66 ft-lbs
The pattern is the same for all 4.3 V6 engines in all models11_7_2011_8_15_34_pm.png
Nov 07, 2011 | 2002 Chevrolet Astro
Need torque specs and bolt pattern for 96-2003 cavalar head gasket please send to mike@rstorage.net
Fig. 7: Location of the cylinder head retaining bolt holes
Fig. 13: Cylinder head bolt torque sequence for 2.2L engines
Tighten bolts in sequence, tighten the long bolts to 46 ft. lbs. (63 Nm) plue 90 degrees. Tighten the short bolts to 43 ft. lbs. (58 Nm) plue 90 degrees.
Hope helps.
Mar 18, 2011 | Chevrolet Cavalier Cars & Trucks
What is the torque on the head bolts and sequence on a 760 volvo 2.3 turbo
The head torquing sequence for any cylinder head is as below, continue the pattern if there are more than 10 bolts:-
10 6 1 3 7
8 4 2 5 9
Start at the middle two bolts and do your sequence at least three times, first at about half the torque, then the full torque value at least twice. It is good practice to re torque the head again after about 1000 km (600 miles), but this is often disregarded due to the problems of getting to the head bolts.
Jan 29, 2011 | 1988 Volvo 760
I need lower manifold rocker and upper manifold torque instructions please help
Head Bolts
Torque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation.New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
The Intake Bolt Torque 10 Foot pounds (Final torque)
Note:to torque bolts & nuts, start in center using crisscross pattern working outward
Dec 05, 2010 | 2000 Pontiac Grand Am GT
Sport & Outdoor - Others Logo
866 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
