Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
No image Suddenly, and for no apparent reason, my camera insists that the cap lens is still on while I'm trying to view. It's not! The warning disappears eventually, but there is no image through the viewfinder or the lcd screen. Other wise all the right noises and motions are being made, - there's planty of power. I can't see a thing, though there is a hint of some filtering light. HELP!!! Karen
  • 6 more comments
  • wilo2000 Nov 15, 2008
    in camera mode the screen remains blanks as if i had'nt removed the cap
  • danaandjenni Nov 16, 2008
    I am having the same problem, with not only mine but my parents. Both are GR-D90 models.
  • aprochaska23 Feb 23, 2009
    I also have the same problem with the same model camera. I have not used it in months and went to break it out and black screen, just the lens cap is still on. This happens in camera mode. I also have the problem with the lcd screen and the view finder. Now I do not have an error message or any error codes. And I can watch movies off my tape, but thats about it. I tried reseting the camera like sony's website told me might fix the problem. If anyone really has a fix to this, I would love to hear it.
  • Anonymous Mar 29, 2009
    same problem, screen is blank in camera mode. no error messages.
  • pjschneider Apr 03, 2009
    Same problem after a few months of non use!
    same problem after a few months of storage and non use
  • Anonymous Apr 24, 2009
    taping with the pen helped. and image is back.
  • trv27 May 20, 2009
    Tapping (more like banging) with a plastic marker around the edges of the lens housing worked for me.
Believe it or not, I just solved this problem yesterday. Take something hard, I used a normal pen. And just tap around the lens. Not right on the glass, but like around the dial. Might have to tap a little hard, but dont break it of course. I did this with the camera on so that I could see the screen pop back on. When I did it, the video came right on like I had taken the lens cap off. Hopfully this helps some people!
Posted on Feb 24, 2009
  • Luis Nov 25, 2010
    I haven’t used my Sony DCR-TRV27 for a number of years because it was broken. Even the repair shop couldn’t fix it. I ended up getting a new camera, but none of them now have an external mic input which I needed for work. I saw your article and thought, what do I have to loose, so I did what you suggested. After two or three years sitting at the bottom of my closet, it is now working better than ever! Thanks!!!
I took out the 3 screws which hold the front lens on, then played with the wires and tapped on things...it is now working! One screw on top, one on bottom and one under the jack port cover.
Posted on Apr 03, 2009
Same problem, please advise
Posted on Nov 25, 2008
My Canon 40D suddenly came down with the dreaded Error 99 for no apparent reason. I have tried all the usual, battery, memory card, lens, but no luck. Even on the bulb setting the shutter won't stay open....
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Jan 30, 2011 | Canon EOS 40D Digital Camera
Lumix panasonic
Have you tried another card in there?  Sometimes the cards go for no apparent reason at all.  And, of course, sometimes for an actual reason...the most common being pulling the card out of a card-reader while data is transferring.
Anyway, the card is the first thing to check/replace - if only because anything else it could be gets expensive.
Mar 17, 2010 | Panasonic Lumix DMC-FZ50K Digital Camera
PSD Warning Panasonic DVX 102A
I can help you with this.Disassemble the right side which includes the lcd display,so you can see the lens unit.Use a blower to blow air inside and point it to the lens.Better if you can remove the lens unit and blow air on it with caution and then assemble it back the problem disappears.
PS
If problem insists remove ccd block and apply inside a small amount of grease on the metal axis inside ois coil which is used for moving coil mechanism for optical stabiliser purposes.CAUTION THIS ONLY IF NO RESALTS WITH THE ABOVE METHOD.GOOD LUCK!
Nov 04, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Camera worked great until last month!
OK, it is known problem of CCD Imager chip failure in JVC GR-D33 camcorder and ccd imager will be replaced to get live view for recording, lens cap message will disappear as well.
JVC will repair your camcorder free of cost for same problem, click JVC CCD Imager Support for details.
Thanks.
Sep 18, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Fuji FinePix F710 photos blacked out
hi
i think the settings on the exposure or apparture have been modified
reset the camera to factory defaults once to check this and you can have the photos back in order
happy clicking, enjoy
pls rate if this was any help
Jul 13, 2009 | Fuji FinePix F710 Digital Camera
Hi my camera is telling me to...
Is the camera turned on? Removed the Cap on the Zoom lens? Try turning it off and on, while the cap cover on the lens is removed, then press the heart button and take some photos. What specifically is the warning?
May 07, 2009 | Panasonic Lumix DMC-FZ4 Digital Camera
Lens Cap Warning & Gray Distorted Display
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Jan 01, 2008 | JVC GR-D20EK Camcorder
AF TROUBLESHOOTING
The secondary small mirror that guides the light from the lens to the sensors ( sensors sit at the bottom of the mirror box , underneeth the main mirror ) may be out of position. To check : take lens off and gently lift the main mirror half way up ( pushing up ) and see if the secondary mirror is dangling ( which it should not be doing ). Correct 1) reingage spring 2) reingage hinge.
Aug 07, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Camera not displaying image
after taking pictur. picture appear small or, technicolor screen
Jun 15, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
579 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
