Question about HP vs19 (Silver) 19" LCD Monitor
HP 19" Monitor Blinking
Question was: HP vs19 19" LCD Monitor power button is blinking blue and there is no display on screen. Video card is fine...other monitors work on system. Any ideas/solutions?
can't seem to be able to attach photos as requested - do you have an email address I can send them to?
gerry
  • Fran Bednar
    Fran Bednar May 11, 2010
    bammbamm@ptd.net is the email
  • HP Master
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power lcd green light keep blinking. Any solution? thx
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Feb 01, 2010 | HP L1906 19" LCD Monitor
HP vs 19b LCD monitor power
You need to start by looking at the power supply section first for bad caps, the problem can also be in the inverter or bad lamps. does it do the same when it is hooked up to other PC?
see the one I just fixed with bad lamp problem: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Post
Feb 01, 2010 | HP vs19 19" LCD Monitor
Monitor problems--screen is blank but power button lit
Check you video card first, if you can remove it, then have it clean, the contact with an pencil eraser, just make it sure wipe the eraser residue, then put it back again, also check the built in fan on your video card, make it sure it is running
Nov 02, 2009 | HP vs19 (Silver) 19" LCD Monitor
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
win
if bad monitor start a post how to fix a bad monitor (endless answers)
Mar 20, 2017 | HP vs19 (Silver) 19" LCD Monitor
HP vs19 monitor does not turn on.
You may have to inspect the inside of the monitor. You may have to dry it out from the inside and look for burned component which may be caused by a short due to the moisture.
Aug 15, 2009 | HP vs19 (Silver) 19" LCD Monitor
Higher resolution
I f resolution is increased your display will not suit hence either add an additional Nvidia Graphics card which supports the resolution and try should work fine.
Apr 02, 2009 | HP vs19 (Silver) 19" LCD Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
Blinking power up button
Its a powersupply problem in your LCD screen, i had the same thing happen to me- i found a site where you can fix it yourself- heres the link. http://computerguru365.blogspot.com/2008/01/fix-that-lcd-flat-panel-monitor.html I did it and it works.
Apr 01, 2008 | Gateway FPD1975 19" LCD Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
280 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
