My archos says Recovery (code 102) and the 3 options that i select dont work
  • Navaneeth Dec 18, 2008
    I have the Archos 605 Wifi 4GB i also face the same problem Recovery code 102. and it's giving 3 options and non it's working
  • Anonymous Jan 08, 2009
    same here.
I am afraid you are going to have to return it to France for technical repair. They will do it, but it will cost you postage both directions and take 3-5 weeks.
Posted on Jan 08, 2009
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
Wont start recovery 102??
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
Sky DD
Jul 09, 2009 | Archos 605 Wifi Portable Multimedia Player
When i switch on my archos 405 2gb it comes recovery code 102. it gives three options ''no'' ''repair'' and ''format''. i clicked on repair but it restarts and it comes the same thing again. What am i...
I think it means 'File system FAT error'. Use the solution above by IPOD tech for reformatting the hard disk. It should be OK. I used the solution to reformat my archos7 last night, and it is working fine.
Jun 13, 2009 | Archos 405 Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
Getting a white screen with 102 error message
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 wi fi fault
have you tried resetting the machine on the bottom their is a tiny hole put a reasonable sized safety pin through that you use for a babys nappy.I found this reset my archos!!!!
Nov 20, 2007 | Archos 605 Digital Media Player
177 people viewed this question
 Grubhead
Grubhead
