Question about Car Audio & Video
Why my alpine v12 amp is getting hot and melting fuses
It keeps melting the fuse on the amp
  • bj_limpin May 08, 2009
    can anyone help me..
    im a newbie in the car audio realm and my v12 amp get relatively hot after running my system for about 30 mins or so. im not sure if my is getting hot beacuse of the speakers that are connected to it. can anybody help me pls.
    my amp is an alpine v12 f805 4 channel 3600 watts.
    connectet to its 1/2 channel are a pair of kicker 6x9 coaxials ex693, a pair of 6" kicker seprates(note sure what model, and a kicker comp sub 12". im not sure about their ohms and what not so i have trouble in checking if my amp is capable of pushing those speakers so im going out of my mind beibg paranoid on why my amp is getting almost to hot to touch.
    this is the only problem i got right now. not shut down of system has occured yet.
    an aditional question.. does it really smell diffrent after running the system? i mean, it dosent smell like its burnt or anything, i here is just a difrent smell in the car unlike when i did not have the system, is that normal? help please to ease my mind. thank u and God Bless
    correction for amp connections..
    connected to the amp's channel 1/2 are the pair 6x9 coaxials and the pair 6" seps.. bridged to the 3/4 channel is the 12" subs. gains 12 o' clock.
    thanks
You may have to big of a load. The speakers may be to low in ohms and the amp cant push speakers that low or there is a short in the wire going to the speakers
Posted on Apr 09, 2009
  • 68 Answers
It might have a short in the amp, or you could be trying to push to much voltage through it and it all depends on what size speakers you are trying to connect to it
Posted on Nov 18, 2008
  • steven plencner Nov 18, 2008
    or it could be to small of fuzes for that amp
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
MY AMP KEEPS BLOWIN THE FUSE...i CHANGED THE GROUND AND HOT WIRE TO BIGGER GUAGE WIRE AND THE PROBLEM STILL THERE ..........THE AMP IS A ALPINE MRV-307
Hello creelb22,
Fuses usually blow because of a short of too much current.
Test your wiring (including the speaker wires) and make sure they are not shorting or grounding against the vehicle chassis. Also make sure that the speaker voice coils are not shorted.
Hope this helps.
Jul 25, 2009 | Alpine MRP-F300 Car Audio Amplifier
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
Fuse
try a 60 amp fuses if it doesnt blow when you crank it up it safer lest chance to frying something 100 amp is lots of juice
Jan 17, 2008 | Alpine MRP-M650 Car Audio Amplifier
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
No power to amp
soundsto melike an underrated ground system. make sure that your ground cable is clean and is connected to the frame.
Sep 02, 2007 | Alpine MRV-F545 Car Audio Amplifier
Car Audio & Video Logo
802 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
