Question about GE 31GT720 31" TV
31GT720 GE Stereo Monitor
I have hooked up a dvd via the jacks on the back of the DVD and the TV. I get sound but a message on the screen saying "Unreadable signal". Will an S Video connection solve this problem vs. the red white yellow jacks I'm using?
  • 3 Answers
I have the same TV. Make sure you have hooked up the red, white, yellow leads from the "out" jacks on the DVD to the same colored "in" jacks on the back of the TV. You also have to make sure your TV is set to Video Mode. I do this with the GE remote that came with the TV. There is a WHO-INPUT button on the left side of the remote, 3rd from the bottom. Toggling this button should switch you between TV and Video mode. Hope this works for you.
Posted on Feb 20, 2009
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
O.k i hook the dvd vcr to the tv andtv still says no signal
hook via the audio and video INPUT jacks from the out jacks on the dvd/vcr
May 14, 2012 | RCA TruFlat 27F520T 27" TV
I wanted to know howcome i have no sound on my dvd player thats hooked up to my screen tv which the lap top is hooked up too
Sounds like you are using an S-Video out, unless you have the Dell dongle to also split out the audio, you'll have to out the audio via the headphone jack
May 20, 2010 | Dell Inspiron 8500 Notebook
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Sound but no picture on TV
Try hooking your components up to the "AV1" and "AV2" jacks on the TV. I experienced this when hooking up my DVD and VCR (movies of my kids so kept it around). I hooked one to AV1 jacks and one to COMPONENT jacks and had the same result you're describing. Hope this helps.
Mar 28, 2009 | Philips Televison & Video
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
Picture but no sound on Hyvision LCD monitor MV190
I had the same problem. The speakers are mounted below the the LCD Monitor. There is no internal connection between the speakers and the TV Audio. There should have been a short patch cord in your box having one jack on one end and two wires with mono jacks on the other. Plug the stereo jack into the audio out on the monitor and then plug the other jacks into the left and right side of the speakers (the wires should be marked L and R). If you cannot find the jack, I'm sure that you can find one on line or get one from Radio Shack.
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
319 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
