Question about GE XL1800 1100 Watts Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
After cooking some popcorn was finished, I opened the door of the microwave. The interior light exploded (shattered). When I took out the food and closed the door, the fan went on. I tried pushing buttons on the keypad to stop cooking but nothing worked. The oven seems to work as normal otherwise. I can cook in it but need to unplug it or keep the door open to shut off the fan.
  • 108 Answers
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Posted on Nov 16, 2008
My ge spacemaker xl1800 light and fan turn on when door is opened. small piece of foil does not spark during this. is there an easy fix?
Kent, most microwaves will turn on the light when you open the door. As for the fan coming on, does it do that all of the time or only after you have used it for a period of time? If it does only after you have used it, you might want to check the back and the underneath of your microwave to see where the fan draws air into the unit and clean any lint built up on the vent holes. Hope this helps!
Feb 09, 2015 | GE JVM3670SK Profile Spacemaker XL1800...
GE PVM1870DMWW
Check those 3 micro switches in the door latch assembly
Nov 15, 2017 | Microwave Ovens
GE Profile XL1800 light out and fan starts running when door is closed
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Jan 31, 2013 | GE XL1800 1100 Watts Microwave Oven
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
GE Spacemaker xl1800
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Sep 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1400 Spacemaker Microwave
Clean all the visibility of the microvave which causes the light switch logged. pls consult the user manual in cleaning the oven.
may help, melnavz
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Leaking microwave oven???
The steam is perfectly safe, as with any other oven it has vents. Just as long as the door is shut and intact your safe.
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
437 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
