Question about SySTOR Systems (400S52) Burner
Riello forty keeps cutting out when only ignited for a few second
It lights then goes out almost straight away.fuel supply is good no electrial probs
  • 1 more comment
  • urbane4 Nov 17, 2008
    It seems that the control box (which contains the transformer) reverts to pre-purge mode several times when starting up, as there is no oil spray in the combustion chamber during the seconds the burner has not ignited, yet the flame sensor does not shut down the motor.
    This is most likely to happen after the furnace has been idle for a long time such as when the night time thermostat setback has been reached and the thermostat calls for heat.
    New nozzle, electrodes correctly adjusted, new porcelain electrode holder, new control box (old one had spark erosion damage in area between electrode contact area).
    The burner usually does eventually stay lit after five or six of these brief dead cycles, but the flame sensor occasionally shuts the burner down.
  • Anonymous Dec 21, 2008
    I have the exact same problem and have since the day the burner was installed
  • rosborough17 Feb 11, 2009
    Exactly the same problem.
    I find it is worse on colder evenings.. for whatever reason.
    Especially if the furnace hasn't been running for a few hours and its particularly cold in the basement.
Too much air. Adjust the air shutter.
Posted on Mar 30, 2010
I've had this problem twice before. If you don't have a full tank (I get 200 litre deliveries) tilt the end furthest from the line out up on some bricks. Turn the thermostat on and try every 5 mins at the burner. It took for me on the 5th or sixth try. I don't have a clue about these systems or if that was in anyway dangerous but it has worked for me the last two times I've received a delivery of oil after the burner being out of use for prolonged periods
Posted on Nov 14, 2012
I have had a similar problem , I found a good clean of the nozzle area helps but changing the nozzle /jet and resetting the electrodes should cure it
Posted on Nov 21, 2008
My vauxhall combo battery light keeps coming on and drains battery after few days. tried a new battery and same happened. fizzing sound near fuse box. Any idea what the problem might be?
I might have a similar problem, I brought the van 2001 combo 1.7. Put a new battery on earths have been checked new alternator, still killed the battery, Realised the battery light wasn't coming on when turning ignition, changed the bulb and was fine for about a month then the battery light started flashing. I have a relay (yellow) near the bonnet release which is clicking. I would strongly suggest checking the output of the alternator before considering replacing. www.willstar@gmail.com is my email address if you manage to figure your problem out please let me know as it might help me from pulling my hair out.
Jan 27, 2010 | Enlight Combo (5601908) (Beige) (5601908)...
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Dell Inspiron 1501
If the laptop keeps working, and you can use it on an external screen, then it is likely an hardware fault.
First perform a complete system recovery, like probably already instructed by the Dell support helpdesk. This will practically exclude the possibility of a driver or system problem.
If the problem is hardware , then you may have a faulty inverter board , a bad LCD display/LCD ribbon connection, or a faulty video adapter (integrated with motherboard).
If the problem is the inverter, then the screen will go dark, and the laptop will keep working on external display. This is probably your case.
If the problem is LCD display or ribbon cable, then the display will be blank with light on , and the laptop will keep working on external monitor.
Fault concerning video adapter usually cause the the system not to work at all, and it is uncommon under conditions described.
Sep 04, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Wont work
Dear Mitodelvalle,
Here are few things that you might want to check:
  1. Open the chassis of the computer and make sure that the cables that go to the drive are properly connected .. there should be 2 connectors.. One for Power supply with 4 wires and one is a ribbon cable for data. Make sure that the power supply cable is properly connected. you might want to remove and plug it back just to be sure.
  2. If that doesn't work then most of the computers come with a spare power connector hanging loose, you might want to try the spare connector.
  3. Try ejecting the optical drive by inserting pin in to the small hole in the front of the optical drive, just below the tray... Straighten a paper clip and insert it straight into the pin hole below the optical drive's tray and the drive should eject, then pull the trey out gently with your hand and make sure that nothing is broken inside...
Try the above steps and that should help. If you still need assistance, please let me know and I would be glad to assist you further.
Regards,
Srinivas.
Jun 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Oil went too low, now don't start
There is a bleed screw on the pump, turn a 1/4 turn to the left, and bleed until oil is free of oil. On older pumps, instead or a bleeder valve it is just a plug, you will have to remove the plug, bleed, then replace the plug
Apr 06, 2009 | SySTOR Systems (400S52) Burner
My furnace is exhausting very fine black ash what causes this? It has a Riello Mectron 3 M burner. I have replaced the fuel nozzle, fuel filter and air shutter hydraulic jack. The turbulator setting is at...
The fine black ash is called soot, and is a by-product of incomplete combustion. The burner should be set up and adj. with the proper equipment. Your OEM specs are a good starting point, but without performing a combustion efficiency test, it is not possible to properly set up a oil burner.
Mar 15, 2009 | SySTOR Systems (400S52) Burner
Riello oil burner
i have a reillo oil burner that fires up from cold no problem reaches the set temp and cuts out, when it tries to kick back in it keeps clicking the lockout light is not coming on and the fan is still running any ideas?
Oct 08, 2008 | SySTOR Systems (400S52) Burner
Trouble transferring video to DVD
hi...
have you uninstall and reinstall your burnning software? change your DVD-R brand, slow down your burnning speed, update your mainboard chipset
may help
Jul 21, 2008 | JVC Computers & Internet
LG E300
You have to remove a few more screws from the base that hold down the silver bezel that goes between the top of the KB and the lcd screen. then remove the bezel(start from far left side, lift silver bezel with fingernail and it should come out easily, then remove/tilt up the keyboard (watch the cable!), then pop open the silver little cover and youll find your other memory slot.
(prob. with a 512mb stick in it)
Obviously, do this with power off!
HTH
JoshAU
Feb 26, 2008 | LG 52 x 32 x 52 w/SF Internal CDRW Burner...
Computers & Internet Logo
1,329 people viewed this question
Top SySTOR Systems Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
