Question about RCA 27R410T 27" TV
TV wont turn on?
TV has been working fine all along, only 3 years old this November. Quit working this past Monday. TV will not turn on either by power button or remote. I have tried unplugging the set and leaving it this way for a few days. I've tried testing a couple of times plugging the set in. Each time I plug the set in, after a few seconds it begins to make a hissing sound. No picture or sound of course. Hissing sound does not go away, wont turn off either by power button or remote. Have left set unplugged.
  • 65 Answers
This product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Posted on Dec 09, 2006
  • beldar conehead Dec 09, 2006
    actually i just rembered what is wrong with this chassis
    they were known for loose connections around the horizontal drive circuit
    resoldering the middle of the board will restore the raster
Burning smell, then quit. 4 yrs old.
That is not a good sign, the problem is in the high voltage, especially if it was a funny smell it would indicate the high voltage transformer "flyback transformer" is toast along with other parts. The set is 4 years old, and new tv's are designed to break down anywhere from 3 to 5 years, probably more cost effective to buy new.
Jan 13, 2011 | Philips Magnavox 27MS343S 27" TV
My Olevia LT37HVS will work fine for a while then all of a sudden shut off. It's only 3 years old...Doesn't stay on all day/night. What could be the problem?
Most LCD TV breaks down after 2~3 years, even if the TV is turn off, the power supply and the processor are running 24/7 when it is plug into the outlet. Any surges and spike that come along in the last 3 years, you TV will affected by them.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Unwanted rebooting of laptop
you may not be able to go farther back than november, but if you have a virus, restore wont fix it. if its not a virus, it could also be the power supply unit.
Feb 27, 2009 | HP Officejet 4215 All-in-One Color Photo...
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Sep 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
RCA 27R410T 27" TV Logo
208 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
