Question about Car Audio & Video
Need instruction book code Goodmans GCE7101 CD Player
Taken this car radio out of scraped old car want to put it in new one cause it got a line input.
Dont want to cause cant remember how to enter the default code, I know i didnt change it so should be as per the book.
Did it once before when battery was changed in old car and know you need buttons in a sequence.
Can you help
5 Suggested Answers
SOURCE: security code
AudioBahn A3351 CD Player reset security code
Posted on Dec 04, 2007
  • 476 Answers
SOURCE: Entering radio code
To enter the radio code on most Renaults you do not use the buttons on the radio. Instead use the remote control buttons on the steering column.
The remote control has a rotary control, (either vol +/- or track/station +/-), use this to set each individual digit.
The bottom button on the controller moves to the next digit of the code.
When you have the correct code on the display, press and hold the bottom button to enter the code.
You should hear a beep and the radio should start up.
You have 3 attempts to enter the code. If an incorrect code is entered 3 times, then the radio will lock up for about 30 mins before it will allow you to try again. If this happens 3 times, then the radio will lock up permanently.
If you don't have the correct code, or the radio is locked, then there are companies which can re-code the radio.
Posted on May 02, 2008
SOURCE: car stereo code input protocol for blaupunkt 520 car audio system
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
Posted on Jun 14, 2008
keemo68
  • 1263 Answers
SOURCE: 1994 Honda Accord Anti Theft Radio
the vehicles ecm is still recognizing the old alarm and should be cleared through a scan tool. the ecm needs to be reset
Posted on Aug 28, 2008
SOURCE: my cd player in demo mode how i change it
Press the Selection button about 3 seconds
When the Demo On mode appears
Turn the VOLUME dial until Demo Off appears
Press the Selection button again to get out of this mode.
Done.
Posted on Oct 27, 2008
Car Radio/CD player -Clarion R.D.S./EON- numbers on back PW546174 - I need a manual please
Hi
Go online to MANUALSONLINE.COM put the brand name in its place and the the code.
kolbbrun
May 14, 2012 | Goodmans CD car radio GCE358MPT CD Player
I need a manual for Goodmans car radio modelGCE 7357MP3
http://www.cintelcorp.net/goodmans-gce-7350-mp3r-manual
download from this link.
Nov 06, 2011 | Goodmans CD / MP3 car radio GCE780MPT CD...
Radio signal strength not very good
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
May 21, 2009 | Goodmans CD car radio GCE358MPT CD Player
CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
May 20, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
COMPATABILITY
MY GOODMANS CAR CD PLAYER AS BROKE , THINKING OF BUYING ANOTHER WILL IT JUST SLOT IN TO THE EXSISTING FASIA. OR WILL I HAVE TO REWIRE AGAIN.
Jan 09, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
Car Audio & Video Logo
249 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
