Question about Toshiba Televison & Video
Set up av on Toshiba CT-871
Trying to set up av on Toshiba CT-871 and cannel find a channel
Must Have been dirty connection tried a second tv it worked when back to the original it worked ???
Posted on Nov 16, 2008
Weve got a toshiba tv model 289s4A & want to plug our ps2 into it, cant find how go get the av channel on the tv. We have connected the av cables but when you change channels on the tv, theres no...
If you have the remote, look for the source button. It should allow you to toggle the settings.
Otherwise they are usually after channel 2 as in Hdmi, Av1, AV2 etc..
Good luck
Dec 09, 2010 | Toshiba Televison & Video
Trying to run a mac mini to philips flat tv
Hi Ralph
Normally it's either one of the AV channels OR the channel marked RGB.
What connector are you plugging into on the TV?
Jan 21, 2010 | Apple Mac mini
Biiig problem
Be very carefull with your remote it does alot more then just turning on TV you have to have it to Get into Service Mode in the event you need to repair TV! Have you replaced Battiers
Nov 12, 2009 | Toshiba 50H82 50" Rear Projection...
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Jan 26, 2009 | Toshiba CT-90157 Remote Control
Tuning a Toshiba CT 9689
I just tried finding a manual for the toshiba and didn't find much. In the setup menu there should be an auto setup for tuning in channels. Cable or off-air. Let the system do an auto set-up to find channels available. I'll keep looking for a manual. Let me know how you do.
Sep 22, 2008 | Televison & Video
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
340 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
