Very light printing
Whether I print from the printer menu or the computer I get printing so light I can hardly see it. I installed new toner and set print density and
toner on high - no difference.
I have a HP 5100 TN
  • rp95 Nov 17, 2008
    I have removed and looked at the transfer roller. It appears to be in good condition. It is not worn
    or damaged. How do you determine if it is bad?
  • 39 Answers
One thing you can do, and this part directly affects print darkness if bad, is to replace the Transfer Roller. It is a roller with a steel shaft, located beneath the toner cartridge, and it is part of the printer itself. easily removes if you pull up from one side it will come free of the plastic saddle clip, and the other end of the shaft is in a round hole slot. replacing this part with a new one will probably restore print darkness.
http://www.fusers.com/shop.cfm?page=list.cfm&action=list&criteria=64&cat=58&makeid=14&modelid=15005&var1=10&var2=&var3=&man=&afid=204&stay=
ken
Posted on Nov 15, 2008
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    We changed the toner on the printer and it prints a blank page. What do we do
    If new toner was installed and it prints blank pages, please try to print a menu settings page to determine if the problem is part of the printer or an issue external to the printer.
    If the menu settings page prints correctly, the source of the problem is external to the printer. To find out if the problem is only with a program, try printing from a different software program. To find out if the problem is only with a particular computer, try printing from a different computer.
    If the menu settings page is blank as well, this will narrow the source of the issue to a part on the printer. Please contact Lexmark Technical Support for further assistance.
    Aug 12, 2011 | Lexmark E260dn Laser Printer
    Is there a print counter on Lexmark E120N? I've just installed a new toner and wondered whether I could check how many prints I got from the started cartridge and how many I get from this new one. Whilst...
    Press the green "play" button and it will print out a stats page telling you all the information about the printer, including print count. There is no way to vary how much toner is used through the printer, only by using the software to vary how heavy or light you would like your documents printed. When the drum (photoconductor) is starting to fail, the light which flashes to tell you the toner is low will come on and stay steadily lit. If you replace the toner and it doesn't go out, then more than likely the drum is ready to be replaced. Very simple to do and should come with instructions on how to reset the drum counter, if not a call to Lexmark tech support will answer your question. We have one at my work and have had to replace our drum already. It was simple and the tech was very helpful.
    Oct 18, 2010 | Lexmark E120n Laser Printer
    I have an HP Laserjet M1319f MFP printer, when I print it uses alot of toner. How can I program it or what can I do on the computer to use less toner?
    You can set the density lighter or put the printer in economode. You may not like the print quality as it will be extremely light. But the toner will last longer.
    Save toner
    1.
    On the File menu in the software program, click Print.
    2. Select the driver, and then click Properties or Preferences.
    3. On the Paper/Quality tab, click EconoMode.
    4. Click OK.
    Nov 05, 2009 | HP Laserjet M1319F Laser Multifunction...
    My samsung ML 1610 printer, printing very light, even though the toner is brand new.pls someone solve this problem thanks
    There's a button on the top called "toner saver". when you press this is prints light to save toner. Press this once to turn "toner saver" off and print normally..
    Aug 17, 2009 | Samsung ML 1610 Laser Printer
    Hp 3015 prints light with new oem cartridge
    Machine may be in econo mode. To enable/disable.
    Hope this helps
    1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
    2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
    Apr 01, 2009 | HP LaserJet 3015 All-In-One Printer
    New toner prints very light. No setting changes on printer.
    I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
    Mar 23, 2009 | HP LaserJet 4p Printer
    2430 DL Kon/Min laser, b&w only
    Hey
    in printer menu you have to look up some setting and tell the printer to continue printing when toner emty, you'll find it in gualiti menu or engie menu, i dont remember exactly.
    second i think you still need to have all toners installed, if C is installed but shows no toner, then you have to clean chip reader under the toner rack.
    Sep 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
    Left side of page prints blank
    Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
    Hope this works for you
    Thanks J
    Dec 12, 2007 | HP LaserJet 2820 Printer
    218 people viewed this question
    jasbo
    jasbo
