Question about GE GSS25JEMWW Side by Side
GE gss25jfmd not keeping cold
I have model gss25jfmd and both freezer and refridge stopped working. I shut off unit for 12 hours cleaned, vacummed, mopped and than plugged back in. Freezer now works fine but fridge only goes to 50 degrees. Any ideas will help
  • shushu268 Nov 30, 2008
    Pretty much the same problem. In my case the condenser fan stopped. The main circuit board was replaced and that fixed the problem, but ever since the fridge will not cool beyond 50 degrees. The themoster? and the circuit board for the temp controls have also been replaced, but has not fixed the problem. It seems that the only time the damper door between the freezer and fridge opens is immediately after the unit has been plugged in (the initial cycle), after that the door doesn't appear to open even though the freezer appears to cycle normally including the fan.
SOURCE: Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Posted on Aug 04, 2008
SOURCE: fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Posted on Nov 15, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
SOURCE: Fridge and Freezer are Warm Ice is still being made
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Posted on Jun 22, 2009
aasc
  • 1606 Answers
SOURCE: GE refrigerator Model#GSS25JFMD Refrigerator is at
Check for frost about 1 foot up on the back wall in the freezer section . Is so , then a defrost problem is there .
Posted on Jul 18, 2009
Freezer cold but refridge is warm
sounds to me your fan is not working its in the freezer unit it blows cold air to your fridge if its turning ,,, defrost the whole unit ... sometimes ice builds up in the tunnel the air flows through . bsc appliances 07779933829 uk
Feb 27, 2011 | GE GSS22JER Side by Side Refrigerator
My GE fridge GSS25JFMD: freezer seems to be working but the fridge compartment is worm, I don't see any cold air flow from the top. Condesor on thr back is very hot and cooling fan doesn't turn on. I...
The control to the fan comes from the main unit and it runs all the time,. So check out the wiring for the voltage to appear on the fan terminals , there can be break of contact in joints of wire connectors.
Once the fan works the fault must clear off with the cold air blowing.
Sep 19, 2010 | GE Refrigerators
Freezer not worknig.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | GE GSS25JFM Side by Side Refrigerator
My GE side by side (GSS25JFMD WW) is not cooling. It's blowing cool air, but not cold .
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side Model GSS25JFMD 2 yrs old. Original problem was not staying cold. now I see if I unplug for half hour it seems to work right but sometimes freezes in fridge . I'm hearing a clicking sound...
Looks like a thermostat problem. The condensor is running but unable to stop when it should. It is the thermostat that should shut it off.
This is a very sophisticated fridge/ freezer and with electronic controls.
There is not much diagnostic you can do yourself other than replacing parts. If you are not comfortable with this type of equipment you should call the professional.
Good Luck.
Feb 27, 2010 | Microwave Ovens
Fridge is not cold, blowing air, but freezer is working fine.
there is a blockage between freezer and refridge airfow take food out shut unit down and let sit for 1 hour
Jan 24, 2010 | Amana Refrigerators
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Ge Freezer not working
with min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Oct 12, 2008 | GE GSS25JEMWW Side by Side
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
GE GSS25JEMWW Side by Side Logo
271 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
