Question about Nikon 3-9x40 Buckmaster Riflescope With Bdc In M
Sighting in my scope
When I am done sighting in my scope and I have moved my inside dial to where I would like it to stay, what do I do with the outside ring? Does it need to line up with the arrow or dot from the inside part of the scope that I adjusted to sight in my scope?
    Problem Solver:
  • 8 Answers
That should be covered in your manual.
If not, give Nikon a call.
Or, repost your question on a Bulletin Borad such as at SWFA, where another user may have the identical scope.
Posted on Nov 26, 2008
I just bought a 4-12x40 trophy xlt rifle scope with an adjustment of numbers on the bell. What is it?
That is a parallax adjustment. You set it for the distance you are shooting at. It appears to be marked in both yards and meters. This adjustment assures the reticle does not appear to move when your eye is moved slightly from side-to-side. Set it for 200 and look at a target at 50 and move your head very slightly side-to-side and you will see the difference.
Sep 17, 2014 | Bushnell Trophy XLT Riflescope 4-12x40...
My cross hairs do not move when i adjust my sights. i bought a laser bore sighter and the laser points in the same exact spot no matter how far i turn my adjustments nor do my cross hairs move.
This happens a lot during bore sighting, - no shock to the scope to jar the cross hairs. So take your screwdriver and use the handle - rap the scope or better just tap it. Not hard enough to bend/dent it but jar it so things can move if need to.
Jan 04, 2011 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
The holder for the sighting scope that is mounted to the main tube of the telescope with two screws is broken and i need to replace the holding part that has two screws so that I can use the sighting scope
I would just replace the entire finder scope with a better quality-- here is one retailer that sells replacement finder scopes:
http://www.telescope.com/control/telescope-finder-scopes
Oct 16, 2010 | Hardin Optical Deep Space Hunter 6 (240 x...
Having trouble sighting in at 100 yards using the center crosshairs off of a led sled shooting rig. groups are barely 14 inches now and it was shooting well a few months ago. please advise Travis
Something is wrong with the mounts, they have to be loose or something. I can hit better than that with iron sights. Unless the internals of the scope are loose. You have it mounted in a sled? Is it bolt action? Take out the bolt, sight down the bore at the target and make it stay there, peek through the scope without moving the gun, The cross hairs should be on the target, if not, you are off to start. Setting up your rifle like this will put you on paper at 100 yards. Check it out.
Aug 09, 2010 | Zeiss Conquest Riflescope w/Rapid Z 1000...
I have a crossman 4x15 power rifle scope. Which way do I turn the elevation/windage dials fro up,down,left, and right?
Under the adjuster cap there should be a scale with an arrow marked up or right (depending on which one you are looking at. If it's not marked, place the gun in a vise (gently as not to crush it, cover metal parts with a towel)
Fire the gun while in the vise at a large sheet of paper several yards away (careful where the bullet goes...use bails of newspaper or plywood backing)
Sight through the scope and move the cross-hairs 'till they are exactly on the bullet hole. After you have done that, keep increasing the distance and adjusting up to compensate for bullet drop till you reach your desired range. Side to side adjustments should only be minor. Before sighting in, make sure that the scope is securely mounted or any adjustments you make will be irrelevant. While sighting, always use a bench rest...shooting "off-hand" will never give you any degree of accuracy because everyone moves and shakes a bit.
Jan 23, 2010 | Optics
When sighting in, it will not move far enought to
I would bring it to the local gun smith and have the scope bases re-aligned. It probably was installed incorrectly.
Apr 11, 2009 | Centerpoint Technologies Optics
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Hi i have an optus telescope when i find a star in my view find or the spacestation orbitating the earth i find it in my view find and when i look through the lens on the scope i see notting and i have...
Your finder is not aligned with your telescope. During the day time focus on a distant small object with the telescope-- then without moving the telescope adjust the crosshairs in the finder to match the telescope.
Dec 27, 2008 | Optics
Just bought used 8x32 swat not sure how to use it. are the win and elev numbers for shooting or just for siteing in rifle
They are for sighting in the rifle only.I know on TV the shooter reaches up and turns a knob.BOGUS! after sighting in the rifle, always replace the little caps because the scope is not sealed unless the caps are on.without the caps, moisture can penetrate the scope and fog the lenses.Good Luck
Dec 08, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Nov 02, 2008 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Nikon 3-9x40 Buckmaster Riflescope With Bdc In M Logo
498 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
