Question about Maytag Atlantis MAV6000 Top Load Washer
How to open the cabinet of Maytag clothes washer A282 top loader
My washer is leaking water. The higher the water level the more it leaks.
1.) How do I open the cabinet?
2.) What are the most likely causes of my leak?
Thanks
5 Suggested Answers
  • 1294 Answers
SOURCE: water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Posted on Sep 11, 2007
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
SOURCE: maytag A212 clothes washer, leaking on fill up.
Possibly Injector / Vacuum break unit has gone bad (mine started spilling water lately, 20 years old). Get a 216201 to replace in your vacuum break, or better (if the machine is older) replace everything from the water valve with a kit: SUB 206680 (INJECTOR HOSE KIT).
Quite easy to get to. Just open front panel (remove two screws at bottom, lift bottom of panel away from machine and swing out. Spring clips at top should release easily. Then remove two bolts that hold top cover down and lift top. Water injector/vacuum break will be at the rear left of the machine. Costs about $40 for the kit. Or $5 for the small rubber part (but I am replacing everything that is pressurized on my machine since it is 20yrs old). -- Kevin
Posted on Jul 07, 2009
  • 105 Answers
SOURCE: I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Posted on Feb 01, 2010
LEAKING SMALL AMOUNT OF WATER UNDER FRONT LEFT CORNER OF WASHER. LEAKS WHENEVER WATER GOES INTO THE DETERGENT DIPENSER.WHAT IS THE CAUSE?
Get a level and check the level of the machine. The front should be slightly higher than the back and even left to right.
Jun 02, 2015 | Maytag MVWB850YW Bravos XL HE Top Load...
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Maytag Model A506 Series 04 Serial 201072 VA, no owner or service manual available. How does the machine cabinet open up? There is a hinge for the top to lift open, but how does one release the latch? ...
If your Maytag is a typical top loader, you insert a putty knife at the front to release the latches. Try going to www.repairclinic.com and entering A506. With luck, you will see a list of common repair parts and may be able to view a generic Maytag video showing disassembly.
Aug 12, 2017 | Washing Machines
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Water leak upon filling at top/cabinet joint
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Feb 23, 2009 | Maytag SAV2555A Top Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leak
If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
Mar 10, 2007 | Maytag Legacy Series Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
289 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
