Question about Compaq Presario S5100NX (E120866) PC Desktop
When boot the system it just makes a steady beeping sound
The system was fine but I guess the memory I tried to stick in was incompatble with the mother board
    Master:
  • 568 Answers
Change the memory
or you can also try cleaning the memory with alcohol or use a eraser to clean the contacts of the memory
Posted on Nov 15, 2008
K7SOM has a series of beeps that are steady..No display.
If it is a long steady beeps , then it could be a problem with the memory.
try reseating the memory,try swapping the memory slots.try to boot the system with individual memory by doing this we will come to know whether the memory slot or the memory itself is gone faulty or not.
most of the cases reseating the memory will fix the issue.
Jan 03, 2011 | EliteGroup K7SOM Motherboard
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
1 long steady beep medion 3100
To my experience one long beep usually is a memory problem. It could be the memory stick itself or it could be the memory slot on the mother board. If you have another memory stick, try to boot the computer with that stick. Try as well to use the other slot. If one of the stick works but not the other, you have a defective memory stick and need to replace it. If one memory slot works but not the other, then it's a problem with the slot itself and there is no fix for it, you would need to replace the mother board if that is the case.
Dec 18, 2009 | Medion Computers & Internet
Satelite L505 powers up then steady beep/won't
Remove and re-seat the memory (RAM) modules.
The task is non-destructive / harmless.
Sep 28, 2009 | Toshiba Satelite A135-S2286 Notebook
Did not boot and with 3 beep sound
Remove added memory
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Swap memory location
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
Vostro bios post beeps
Either your memory sticks are bad or, you have too much memory in the slots. Computers can accept a lot of memory but they can only recognize a certain amount. Make sure you don't have too much.
Jul 31, 2009 | Dell Vostro 420 Desktop Computer
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
Warning beep no boot
Re-seat the video card and memory first,
if it continues to beep count the beeps 3 long ,3 short .etc
they mean a code.
if you have 2 sticks of memory try using one.
Feb 14, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Memory Installation problems
Intermittent problems just about always indicate a hardware problem. Assuming that you've put both memory cards in channel B and they worked fine, I would think the memory cards are OK. The only thing left at that point is the motherboard.
Dec 09, 2007 | Intel D945GCZ Motherboard
PC beeping, monitor will not display
we have different sound we can hear in cases of hardware problem, once the video card has loose contact it also beep continously, a beep sound also occurs when the ram(memory card) loose contact, one beep sound when it boot clearly it proceeds as go signal going to operating system. if you are using an upgraded video card remove temporarily and use the on-board from your motherboard. in case that it won't boot and still you hear a beep, beep ,sound then, switch-off the power take out the memory card clean the contact points(bronze color) with pencil eraser, make sure that no remaining residues of eraser remained before you install to the slot. i hope that this solves your problem
Dec 01, 2007 | Computers & Internet
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
See all Compaq Presario S5100NX (E120866) PC Desktop Questions
Compaq Presario S5100NX (E120866) PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
